Label Job for a Repeat Customer
Fred Weiss
This thread is to document, step by step, our production of a sizeable label job we've done for a regular client for several years now. It is assumed that, for many here, the job may seem routine and not all that interesting. Our hope is, that for a number of others, the information will be helpful and educational. It will also point out to some the value of a Gerber Edge for this kind of a job. The job was for 5,000 labels printed with Spot Gold Metallic and Spot Black foils on white cast vinyl. From start to shrink wrap, the job took seven hours and produced a profit after cost of materials that exceeded $200 an hour return on my time ... the total of which exceeds what our Edge and Envision plotter would likely bring if we sold it on the open market.
Printing is done is two passes, one for each spot color, 5 feet at a time which yields 220 labels per print run. Limiting the length of a run keeps handling easier and also results in better color to color registration.
attachment.php
Our plotter sits at the opposite end of a 6 foot table. We feed the completed prints into it directly so that we can print and cut at the same time.
attachment.php
Once the printing and cutting is done, they are moved to our weeding and finishing area.
attachment.php
After weeding off the unprinted vinyl, we're ready to trim out the labels into single vertical strips.
attachment.php
First the excess release liner is trimmed off the top and bottom of each section on our Keen Cutter setup.
attachment.php
Next the sections are cut down to single vertical strips on our guillotine cutter. The use of a low profile fluorescent light allows the blade edge to be seen through the release liner to avoid bad cuts and get done faster.
attachment.php
Here's a rare photo of your genial host at work.
attachment.php
The trimmed out labels are sorted into stacks of 1,000 labels and finally shrunk wrapped to protect them and create a quality impression for the client.
attachment.php
reQ
Very nice! I like the shrink wrap idea. Right now i am using poly tubing from uline & seal them in there, but shrink wrap is awesome too!
Jburns
Awesome- Thank you very much Fred. As a newer owner of four pieces of gerber equipment ( and now Omega 6) its great to see this type of work.
Drip Dry
15 years with the edge and it never dawned on me to send a job from the edge directly to the plotter.
Thanks for the tip
Fred Weiss
I like the Kleen Cutter setup! I really need something like that!
Yes the Keen Cutter does a great job on soft substrates like Coro or PVC foam. What we like most about it is the ease of keeping everything on the square. When we do an install, for example, we can use the edge of the release liner to measure to and know our lettering or graphics will be square to our substrate.
gabagoo
I would never get rid of my Edge.... Just last week the Mimaki refused to run due to bad chip set...Edge to the rescue...for what it could do to help Besides,you cant print metalic gold on a cmyk printer.
Jburns
Fred,
Do you always prefer to print on Scotchcal 220? I have had some inconsistencies with other brands..and was thinking it may be the vinyl itself.
Fred Weiss
Fred,
Yes. We used a lot of Oracal 651 and 751 for a while but found an occasional conflict between a particular foil and vinyl combination. It was kind of weird because the same foil would print just fine on a different color vinyl and the same vinyl would print great with a different foil.
Jburns
Thank you - yes I have used both 651 and 751 - and seen some imperfections- and possible foil issues.
Will go Scotchcal from now on.,
Fred Weiss
Hey Fred is the blade depth adjustable on that Keen Cut?
We've been looking at getting one and I'm curious if we could use it for backslitting.
:thankyou:
It wouldn't work in conjunction with the table which uses a slot for the blade to extend into. It could possibly work with just the Javelin cutter assembly but you would need a super flat table and then you would lose your depth setting very quickly as the blade point wore down.
Check THIS THREAD for a pretty good discussion of "semi-slitting" solutions. The Champion SS Semi-Slitter always seemed to me to be the way to go.
Ptolemy
Thanks Fred. This was great. What about the business of finding ideal customers like this? Any suggestions on marketing our thermal printers?
Fred Weiss
Show jobs you've done on your website, your store walls or your portfolio book. Be patient and wait for word of mouth.
