Looking for a substrate at .050" thickness that can be backlit
Discussion in 'Product and Supplier Referrals' started by Zeke Ford, Oct 8, 2020.
  1. Zeke Ford
    Zeke Ford Manager of Wide Format Production
    17
    2
    3
    Jan 5, 2018
    Sandusky Ohio
    I have a customer that has three drink coolers that he wants to replace the graphic at the top with his business logo. The maximum thickness that it can be is .060 and that was tight. So, I am looking for a substrate that has backlit capability (Acrylic, clear polycarbonate, etc.) at .050" thickness. I've checked Wensco, Home Depot, and Lowes. Many people only have .080 while others have the thickness but only carry sheets that are like 10" x 14". The cooler signs are about 10 x 36 so I am looking for a sheet that is at least that size maybe even bigger so that I can get all three out of one. Grimco has a .060 polycarbonate but I am unable to get a sample from them and I don't think that the .060 will fit once I apply the graphic. Does anyone have any suggestions or know of anyone who carries the .050 size? It would be ideal to find a supplier that will offer a sample of the product even if it is for a price, just so that I can be sure that it will work before buying the full sheet.
    Thanks,
  2. GaSouthpaw
    GaSouthpaw Active Member
    826
    163
    43
    Dec 1, 2005
    Georgia
    We use a material from Fuji called Excellite for these. It's comparable to Kodak's Translight. It's thin and perfect for those coolers. Otherwise, you could try super-thin acrylic.
    • Like Like x 1
  3. WYLDGFI
    WYLDGFI Merchant Member
    1,290
    145
    63
    Oct 27, 2006
    Linden, NJ
    PETG is clear but thin.
    • Like Like x 1
  4. Zeke Ford
    17
    2
    3
    Jan 5, 2018
    Sandusky Ohio
    Is the Excellite Rigid enough to stand on its own when slide into the slot of the cooler or do I need something behind it?
  5. Zeke Ford
    17
    2
    3
    Jan 5, 2018
    Sandusky Ohio
    Is it too thin to stand on its own? It would need to be fairly rigid.
  6. WYLDGFI
    1,290
    145
    63
    Oct 27, 2006
    Linden, NJ
    You can get in various thicknesses....so if you're laminating a print to it, it would likely stand alone if it had to. Think of styrene handling and it would be similar as to how that works.
    • Like Like x 3
  7. White Haus
    White Haus Formally known as RJPW..........
    613
    170
    43
    Apr 6, 2018
    Winnipeg
    We literally just ran into this yesterday, funny timing. Our samples were printed on what looks like .030 styrene but the front panels are translucent for backlighting, where as styrene is pretty damn opaque.
    I went digging through our acrylic/lexan offcuts and like you, couldn't find anything thin enough.
    The solution we came up with was to print on some .015 matte velvet lexan. We're going to print a couple of layers of white on then the cmyk graphics.
    • Like Like x 1
    • Informative Informative x 1
  8. Gino
    Gino Premium Subscriber
    33,493
    2,387
    113
    Jun 7, 2006
    PA
    These coolers, generally don't have a very bright light, but the lams are close, so you'll need to consider whatever you use, not to get ot spots.
    • Like Like x 1
  9. GaSouthpaw
    826
    163
    43
    Dec 1, 2005
    Georgia
    It seems to do just fine on it's own.
    • Like Like x 1
  10. CanuckSigns
    CanuckSigns Very Active Member
    3,432
    398
    83
    Nov 11, 2008
    Ontario
    I would use PETG for this, i can only get it 0.030" thick but it should still be rigid enough at the size you need.
    • Like Like x 2
  11. Zeke Ford
    17
    2
    3
    Jan 5, 2018
    Sandusky Ohio
    This project has been in the works since the beginning of the year. When COVID hit the customer wasn't open so it got pushed back. Now that they are opening up again we have to get this figured out. That may not be a bad idea though. I will have to look into that. I want to try to see if I can get my hands on that PETG material first though to see how that works. Thanks!
  12. Zeke Ford
    17
    2
    3
    Jan 5, 2018
    Sandusky Ohio
    Do you usually purchase your directly from them or do you have a different supplier? Also, do you know if they give samples?
  13. Zeke Ford
    17
    2
    3
    Jan 5, 2018
    Sandusky Ohio
    I think I might be leaning toward the PETG but I just need to see if anyone will provide a sample.
  14. Zeke Ford
    17
    2
    3
    Jan 5, 2018
    Sandusky Ohio
    I think the PETG might be a good option for this project. Do you all provide any samples? Also do you have a catalog book with all of your products that you offer? We use Wensco and Fellers for most of our signage and materials but would like to explore different options.
  15. GaSouthpaw
    826
    163
    43
    Dec 1, 2005
    Georgia
    I'm not sure, offhand, who we get it from (our purchasing agent is out today). I would imagine a sample would be available. The rolls we get are either 54" or 60" x 100'
    • Like Like x 1
  16. Zendavor Signs
    Zendavor Signs Member
    256
    40
    28
    Mar 3, 2011
    Peoria, IL
    We have used this .030" polycarb before:
    https://www.eplastics.com/LEXAN-POLYCARBONATE-CLR-0-030AM24X48
    • Like Like x 2
  17. Zeke Ford
    17
    2
    3
    Jan 5, 2018
    Sandusky Ohio
    I came across this the other day! I was just concerned about it only being .030" Thickness. Was it still pretty sturdy when you used it? Also, how was it with the backlighting, did it make the image foggy at all?
  18. Zendavor Signs
    256
    40
    28
    Mar 3, 2011
    Peoria, IL
    We didn't use it for backlit prints, but it was just a clear material, no fogginess. It is pretty rigid. The pieces we did were larger than your 10x36, so you should be fine.
