Looking for Aluminum
Discussion in 'Materials' started by WB, Jan 22, 2014.
  1. WB
    WB Active Member
    843
    2
    18
    Feb 9, 2006
    Canada
    Hey guys I need to find a supplier for some aluminum. I'm looking for 5/8"x 5/8" x 1/16" BRUSHED aluminum angle, Like the stuff you can find at HomeDepot in 3-4' length.
    I need about 1000' of it.
    Anyone have any ideas? prefer a supplier in Canada if possible.
    Bill
  2. Chriswagner92
    Chriswagner92 Member
    319
    19
    18
    Aug 26, 2013
    nc
    I'm not sure if they go to Canada or not but we use either BMG or Eastern Metal Supply
  3. CES020
    CES020 Very Active Member
    2,875
    4
    38
    Oct 16, 2008
    VA
  4. WB
    WB Active Member
    843
    2
    18
    Feb 9, 2006
    Canada
    Yes what I'm looking for is actually called Satin Finish Anodized Aluminnum angle.. Thanks
  5. Moze
    Moze Precision Sign Services
    2,033
    156
    63
    Feb 27, 2012
    Dallas, TX
    Not sure what your application is, but I don't think you'll find it in structural aluminum. In architectural aluminum I don't think you'll find it in 1/16".
  6. WB
    WB Active Member
    843
    2
    18
    Feb 9, 2006
    Canada
    I found a supplier that makes it on a per/order basis. only issue is the minimum order it 250kg which works out to about 5700' I can buy it at Home Depot but it's rather expensive for a 4' length. I'll keep looking.
  7. joshGN
    joshGN Member
    228
    10
    18
    Nov 8, 2005
    Edmond,Ok
    try metalsupermarkets.com they have locations in Canada...
    if they dont have it, they should be able to get it....
  8. aluminumwelder
    aluminumwelder Member
    130
    Mar 3, 2013
    york, sc
    should cost about $300 for 1000 feet
    I use eastern metal but they do not carry 5/8" aluminum angle, just 1/2 and 3/4"
    1000 ft of 5/8" angle would be about 100 pounds.
    Since canada is a huge country and we have no idea where you are at you can probably just order it from anywhere and get it shipped, it's not that heavy.
    Aluminum currently sells for about $2 a lb whole sale, so figgure $200 for the material.
    buy a $10 wire brush for your bench grinder and have at it.
    Coat with a clear paint like
    http://www.wholesalemarine.com/blog/2010/05/17/toon-brite-protective-clear-coat-faq/
    about $100 for a gallon
    it's not as durable as anodized aluminum but looks good and is easy to apply. but it stinks to high heaven
