Looking for new ways to bend Aluminum Composite
drew_psg
One of our staple budget/profit friendly items are 1” thick pan-faces panels made in-house using a v-bit, handheld router and jig with aluminum composite to bend the edges. I recently found a way to make a single sided post and panel with triangular top that was ALMOST seamless on 3 sides (other than the 3 points of the triangle). The client was ecstatic with the product/price ratio, and we were happy with the product/profit ratio. I’m wondering if anyone has any templates, or creative tips/tricks to maximizing the ability to shape aluminum composite without the need of expensive equipment?
equippaint
Depends on what you consider expensive. We have a magnetic brake, im not sure if itll work with acm but its fine with 063. You can do some pretty cool stuff with it
drew_psg
I’m currently looking for creative ways to form different shaped panels with tools less than $1000. I’m not the owner so I’ve got to have a good “pitch”. We have a very small manual brake, but can’t do much with it. I guess I don’t know the capabilities of a magnetic brake?
Gene@mpls
Safety Speed Cut has an new attachment for their panel saws that carves out a groove in ACM with a blade. Works quite well. Probably more that a grand tho.
JimmyG
I would love to see a picture of the sign you are explaining here...?
drew_psg
JimmyG
Thanks for the pic Drew, and it's big rez enough to zoom & inspect.....Looks like nice joinery....
2B
very clean looking, like the address added to the vertical edge.
zooming in on the image is that backside face the same white/turquoise as the front or just the standard baked enamel white?
for the top of the "triangle", how did you seal it off? V-grooving and folding the flaps leaves a peak opening but the image appears to be seamless on the front edge of the side angles of the top. and I don't see any hex head screws as fasteners if a seal piece was used.
That face looks deeper than 1", or are you talking about 2 different products in the OP?
again good looking, and this will give me an excuse to get the router out and get away from the desk.
