Looking for Summa D60 Drag Head Spare Part
Mosumart Design
Hi All,
I am looking for Summa Drag Head (Spare Part), Anyone here knows where to buy?
Anyone can confirm the blade holder with mental screw (left) Is seperated part (fastened with screw) from the body?
FrankW
The first adress for summa spare parts is a summa dealer. The tool holder part is not available separate from the body.
PHILJOHNSON
Sales Manager
We(Airmark) have the 399-610 cutting heads in stock. The bracket that holds the blade holder cannot be purchased separately like Frank mentioned, so you would need to purchase the entire head if that bracket is busted. I have had customers glue the bracket back together as a temporary fix, so you might try that if you don't want to purchase the entire replacement cutting head.
Best regards,
Phil Johnson
Airmark Corporation
(800)527-7778, ext. 112
philj@airmark.com
Mosumart Design
Best regards,
Phil Johnson
Airmark Corporation
philj@airmark.com
Thanks Phil for reply...
Haha..glue? Seriously? What type of glue..perhaps I need to have a try..for temporary..
By the way can u share the price of 1 set draghead?
damonCA21
If it is the plastic part that has snapped then plastic welding should fix it. If you arent confident doing it yourself then you should be able to find somewhere locally. A lot of motorbike repair places do plastic welding. You can also reinforce it with small metal bars plastic welded into the part and it should last fine
damonCA21
If you are really stuck as I know you have been looking for a while, I can get it done in the UK for you if you sent the part here
chris20630
I have the same problem of small crack in dragholder clamp. Is it simple done to change the head by myself?
Thank you all!
damonCA21
Thank you all!
They are easy enough to change over, but the heads are very expensive ! Around 500 Euro as you have to buy the complete drag head
jerry369
Are you sure? Change the cutting head it's not just removing the old one and fitting the new one.
These are the steps a technician should follow to do a good job:
- Remove old cutter head (ok, this is easy)
- Move OPOS sensor from the old head to new one (this is easy too)
- Fit new cutter head ( ok, just a little attention with heights and orthogonality)
- Adjust coil parameters (....)
- Adjust right margin offset (not that important but if it is done it is better...)
- Adjust OPOS offset and other calibrations.
damonCA21
Well relatively easy in that you don't have to dismantle half the machine to get to the part like you do with a lot of components! Recalibrating a head is normal when you replace something like that, and setting up print / cut adjustments is something most people can handle, so in terms of difficulty I would say it's one of the easier jobs
