LXI Expert V6.5
Silverado
Hello...
Anyone using LXI Expert Version 6.5?
I so, can you tell me if it will IMPORT DWG files??
Thank You.
BobbyFosson
No longer have 6.5 installed but pretty sure it will but have had problems using DWG files for the longest time... Seems like a version issue similar to issues with AI files.
I would recommend having the designer export as DXF or preferably EPS. These files import better into Flexi based products... Otherwise, look into purchasing Corel 12 or X3.
PMG
I Have LXI Master Plus but dont have any DWG files to check !!!!! Your more than welcome to send the file and i will check to see if it opens!!!!!!
Silverado
Hello Bobby... Thanks for the info.
I hav'nt received the program yet. Bought it through Ebay for the sole purpose of importing my old cad files and exporting them to .eps.
I took a guess that since it is a Scanvec product that it would import .dwg.
...Roger
Silverado
Hi Mike.. Check your e-mail I send you a DWG file. Let me know if you can open it.
I don't know how to send an attachment thru S101!!
PMG
It says in the file support that it will open,,but i cant get it to!!![FONT=Arial,Bold]
LXI MASTER PLUS Supported File
Formats​
[/FONT][FONT=Arial,Bold]
File formats supported in design application
File Format Extension Import Export​
[/FONT]
Adobe Illustrator ai, EPS 10.0 6.0
Adobe PhotoShop psd 6.0 4.0
AutoCAD Drawing dwg 2000 ------------Clip Art ca 4 / 5 4 / 5
CorelDRAW Drawing cdr 8.0 ------------
CorelDRAW Exchange Metafile cmx 6.0 ------------
Digital Microprocessor Plotter
Language (DMPL)
plt Note 1 ------------
Drawing Exchange file dxf Note 1 Note 1
EnRoute enr 2.3 ------------
FlexiSIGN 5.x fs, pd, fd, fc, fe 5.9 4 / 5
FlexiSIGN 6.x fs 6.0 6 / 7
Flexi 7 Fs 7.0 7.0
Gerber Art Definition gad ------------ 1.0
Hewlett Packard Graphics
Language (HPGL)
hpg, hgl, plt Note 1 Note 1
Language II (HPGL/2)
Ikarus ik Note 1 ------------
Joint Photograph Experts
Group (JPEG)
jpg Note 1 Note 1
Kodak Flashpix fpx 1.0 ------------
Kodak PhotoCD pcd Note 1 ------------
Macintosh Quickdraw PICT pct Note 1 ------------
Microsoft Widows Metafile wmf Note 1 ------------
Portable Network Graphics
(PNG)
png Note 1 Note 1
Portable Document Format
(PDF)
pdf 1.3 ------------
PostScript ps, EPS, 2ps, fjb, prn 2.0 3.0​
signage
I have ha trouble opening DWG files in sign programs if they open they do not have all the info. I have tried to open engineering type of drawings created in AutoCad and MicroStation.
Kenny
Autocad version is the conflict...have them save it down to Autocad Release 14. If you need it saved down, shoot me a PM.
Kenny
Some additional info: Flexi version 7.5.2 listed the following under the "Import" option:
Autocad 13/14/2000 - dwg
Release 14 - dxf
How the file was created in Autocad will also affect how much you will have to clean up once the file is imported into Flexi.
