Many times automatic cleaning
Lucianoo23
Hi I had a problem with my Versacamm vp540, the machine print very well, but clean automatic many times at 1 job... please help me, its printing a meter of vinyl the printer clean 3 times!!!! and its not neccessary. Sorry about my poor english.
Merry Christmas from Argentina!!!
Saludos! Luciano.
cdiesel
There is a setting for periodic cleaning you can change. Press <Menu> and scroll down to the <Sub Menu>. Under the Sub Menu you should see an option for <Periodic Cleaning>. You can change this to any interval from 10 mins to 990 minutes. I'd have it set to run once a day in most cases.
Lucianoo23
thank you chris, but i still have the problem. A few days ago I change the ink (now I use bordeaux in a transparent cartdriges, but after this problem I used Redgiant inks in 440ml cartdriges) I think the problem is in the cartdriges because these news don´t have any chip like redgiants cartdriges) Is it probably??? thankyou for your response. Salute you. Luciano
threads1
Also, while printing, the machine self-cleans itself so the inks NOT being used won't dry and become clogged.
Lucianoo23
Thannk you!! tomorrow I go to talk with my technical service to fix this problem with new cartdriges with chip included. Very thank you!! Happy new year from argentina!
Luciano.
Lucianoo23
Well I have another question...did you have any idea, if I can power off / switch off this type of cleaning by menu/submenu or service mode menu?? thanks
Robert M
Auto cleaning
Yea, Roland added that feature to it's newer firmware. Use carts without chips and it will run cleans until the ink is empty, nice waste of ink and their way of spanking you for not using their ink in your machine. Just put a roland chip off an old cart on and you should be good.
Adam Edge
It cant be firmware update issue. I have 2 printer both on the latest 4.8 firmware. both using after market inks. 1 does auto cleaning during print and the other doesnt. Could there be another issue?
