Matching 280 Reflective with Edge Colors?
jfiscus
Rap Master
I have a rush job that a sample was provided for, and I have to print it as all one piece (edge print) to match the sample from the customer.
It is a "gold" with "dark green" reflective pinstripes. We have been able to match the gold through double-striking trans gold on 280i white, but cannot come close to the green color needed to match.
Here's the doosie part: the green matches 280 Green Ref Exactly.
Does anyone know how to match 280 Green with Edge prints? We've tried a LOT of combinations so far with none getting close.
We have also tried using 280 gold as the base color and printing combos of other colors on top of that, with similar dismal results.
Our spectratone books list a lot of good close combos for printing on non-reflective colors, but you can't use the non-trans colors in the combo and keep it reflective...
I need help!!! :banghead::banghead::banghead:
jfiscus
Rap Master
Here is a photo of the sample provided zoomed in as best as possible.
The green pinstripe is only 1/8" and the stripe needs to be 50' long...
Fred Weiss
I believe the GerberColor Transparent Series Foils (GCT) are all supposed to be dead on matches for the 3M Scotchlite colors when printed on 280-I.
jfiscus
Rap Master
I thought so too, but I've never had to match 280 green before; the vinyl is darker and has a more blueish look to it than the printed trans green does.
The Gerber Color ID suggests Trans Green over Bermuda Blue as a color shift of only 6%.
It also suggests Trans Green over Process Yellow and Trans Green over Lime Green as close matches, but using non-trans colors reduces or removes reflectivity.
jfiscus
Rap Master
A TRIPLE-Strike of Trans Green on 280Gold gets pretty close, this may be what we go with for the project... Lots of foil use-age when you're printing a 50' stripe!
WhiskeyDreamer
Professional Snow Ninja
You can Spectratone it, just set your colors at 95% instead of 100% and the reflective quality will still come through. I do this all the time with chevrons for the back of police cars.
