Max Metal question
Discussion in 'General Signmaking Topics' started by DKgrafix, Feb 18, 2014.
  1. DKgrafix
    DKgrafix Very Active Member
    I have a customer that needs a 8x4 dry erase board for scheduling.
    I'm looking into a Max Metal board (white).
    Will that work? Did someone try to use dry erase markers on them?
    Would it help if I apply a layer of vinyl or just to laminate it?
    Thanks in advance
  2. Pixels Are Bad Mmmkay?
    Pixels Are Bad Mmmkay? Very Active Member
    I would suggest coating it with dry erase film. As others have told me, regular gloss vinyl might work, but may not erase well if it's written on it for too long. We got a really nice sample of some of this film made by Aslan. I'm not sure where you can purchase it though.
  3. Dovette
    Dovette Member
    55
    I wouldn't recommend it. I had a customer a while back that tried that method--the marker never came off.
    I'd go with JSmoritz on this one--get some dry erase film. FDC has a promo dry erase film that might work. It's the 4305 series, calendered vinyl, 4 mil thick. FDC operates out of South Bend, IN, so it would only take a couple of days to get the product to you. N. Glantz is a distributor for FDC, so they could easily help ya out. I think the number is 513-297-1616...? Or google works, too. :)
    If you've got any more questions, feel free to message me.
  4. cmykpro
    cmykpro Member
    77
    Max metal laminated with scribe (dry erase) laminate works perfectly.
  5. MPW270
    MPW270 New Member
    4
    Many dry erase vinyl and/or laminates are not designed for long term or heavy duty usage. Check the specs, most are 6 month films.
    Keep this in mind so the customer is not upset after just a few months of usage when the film starts to tunnel from repeated erasing in the same area.
  6. FireSprint.com
    FireSprint.com Trade Only Screen & Digital Sign Printing
    Not sure about the films, but max metal doesn't work for dry erase very well.
    I have used .040 aluminum with a white polyester coating (I think this is pretty standard) and that worked a little better.
  7. DKgrafix
    If someone saw a post about selling 15 feet of it, I believe I have everything taken care of.
    Thanks for your help :signs101:
  8. BlueFishDesigns
    BlueFishDesigns Very Active Member
    1,714
    Aug 21, 2006
    Huntsville, AL
    Instead of dry erase, what about painting a board with chalkboard paint? Or just buying a big chalkboard? Might be too messy, I guess. Just a thought.
  9. Mosh
    Mosh Major Contributor
    5,809
    41
    48
    Oct 19, 2009
    Nerbaska
    Melemean (sp) showerboard from home depot works great without laminating it. Other than that use dry erase laminate on MAx-Metal
  10. ddubia
    ddubia Member
    361
    1
    16
    Sep 13, 2006
    Northeast Ohio
    I have used white masonite with good success. Marker left on for weeks and weeks will need an alcohol clean up but it does clean easily.
  11. klemgraphics
    klemgraphics Active Member
    624
    Jan 13, 2008
    Midwest
    I would use a scotch brite to scuff it and put a couple coats of automotive urethane clear on it. I do it all the time and have not had a single complaint yet.
