jardine.jason
Hi i just wondering how to use the Mimaki half cut feature. Can just use the original blade and cutting strip that comes with the machine when new or do you have to buy a different blade and cutting strip?
You also need to specify the cut condition when outputting to your RIP. I have CUT1 set up on the printer for contour cutting the vinyl layer and CUT3 with HALF-CUT turned on and higher cut pressure for the perf cut through the backing layer.
You can use any blade but the 60 degree one should work the best. You can also use the standard cut strip but it will wear out quickly so they offer a sponge strip for that purpose. It's hard to describe how to do it but if you YouTube it there should be some videos and also the user manual goes through it although it is hard to understand. At the end of the day I don't know of a lot of people who use that feature at all and I am a tech who installed them for a living. It's not a very polished feature.
I forget off the top of my head how many cut conditions are available, what is it like five or six?
Having each cut condition set for each material we run was originally what I intended to do, and did for some time. But lately, it's gotten to the point where we are now running more material/laminate combinations than we can have programmed into the machine so I just use the first cut condition (CUT1) all the time and change the settings manually before cutting each job.
I keep a sheet to record the cut settings for each job/material I run and it works out better, at least for me. This also allows me to make adjustments when the need arises, fine tune the cut settings that I use for each type of material, and have a record of it. This has been especially useful for fine tuning half cut settings, which can be daunting, to say the least. But now that I've got my settings down through much trial and error, my half cuts look like perfect die cuts every time.
Point taken about too many material combinations, but that begs the question of how you're going about both contour cutting your design AND perf-cutting the perimeter???
I'm not sure I understand your question, as when dealing with half cut or perf cut decals, the contour cut and the perf cut are one and the same. Am I missing something?
Not always, when my design is not simply an oval shape or rectangular/ circle I use to make a contour cut and then a little larger perf cut as the perf cut leaves a messy finish in tight corners.
Okay, I guess I've just never really encountered that situation. I usually try to limit myself to pretty basic shapes and I set up rectangles and squares with radius corners.
