Need Help Mimaki UCJV300-160 White ink Leak
You can just replace the silicone tubing inside the pump, not too hard (messy), dirt cheap and it's a good thing to do every few years. Just a peristaltic pump run by a stepper. Just unclamp the body, measure the silicone tubing, cut new bits, move the fittings, clamp the lines (zip ties work, but spring clamps are best), install the tubes, lubricate with a bit of silicone grease and reassemble.
I often suggest purchasing. New pump. Simple repair, back up and running in no time.
THEN
at your leisure, REPAIR THE BAD PUMP, put it in the PARTS CLOSET OR CABINET
or START ONE, if you haven’t started collecting spares
the next time, in a oinch, you can sub that pump for one of the others & perhaps not have the choice of 1-1/2 down days, expensive overnight shipping and pissing away an expensive Ink cartridge
Smoke_Jaguar
Yup, no real "wrong way" to do it between rebuild or replace. Do what works best for you.
MY MP31 white cartridge is twice the price of one of the others
i just figure someone who has never done it before is guaranteed success
after that he feels like a pro and he’s got enough confidence if the rebuild has a couple unexpected wrinkles
MelloImagingTechnologies
Many years in the Production Business
Can you all tell me what you pay for Mimaki ink?
I’m about to start a business selling inks for Mimaki printers and want to know how much we can save you.
Bruce
is there REALLY a difference in formulation (besides the different generations,, eco sol, eco sol max, eco sol max 2, etc)
is the mimaki formulation for their inks DIFFERENT, than roland or mutoh? (comparing apples to apples)
I joke and say the printer is just the big metal box that keep the printhead from falling on the floor
willkho
Wondering where do you guys getting the parts from?
In Australia, I couldn't get them except from mimaki.
Smoke_Jaguar
Reading safety data sheets helps on inks. Sometimes, solvents that are hazardous get changed over to more benign substances. Stuff like pigments, stabilizers, flow agents and so on are also important. Some inks jet at higher temperatures or voltages, or require different heads. Sure, most of the formulation between the same types of ink will be largely the same. However, some inks with even slight differences can cause major issues if mixed. Some inks have adhesion promoters and wetting agents that can cause major issues if left in a system that has incompatible ink already in it. Things can get even crazier when you get into UV and oil inks as well, lots of potential with incompatibility. That said, I think good aftermarket ink manufacturers can have ink as good as or better than OEMs. More aftermarket vendors in the UV ink space would be nice, but solvent inks are a crazy competitive field. Some more aqueous pigment inks are nice too, but there's not a ton of demand for those it seems.
Raghaus
I just finished replacing the pump. FYI, replacing the tubing is NOT an option for the UCJV300-160 as the connections on the tubing to the lines inside the printer are threaded and not just flat ends with a coupling. The tubes screw on to the pump lines. One thing to note, as soon as you remove the tubes from the pump, white ink will start flowing out of the lines everywhere. Be sure to wear good gloves since the white ink is caustic and will burn your skin. Clamping the tubes isn't an option since these are semi rigid lines. Something small to plug the lines would work or just remove the white ink tanks and work FAST!!!!
Do you have a part number for the pump? My machine is doing the same thing, outer white pump only.
chaotic-graphics
Best job I ever had!
Does anyone have a part number or name for the small elbow connectors? Those plane jane barbed ones that are a 90 degree angle.
Bumping an older thread. Spent about an hour searching for this answer here and have decided to just ask even if it's been asked.
chaotic-graphics
Looks like I need part #10 on page 46-47 of the 3.10 version document. MP-M017872 / M603917 φ3-φ3 hard L.
I had suspected that was the part from reading through this and other treads but I am not finding it as a purchasable part from our normal suppliers so I had started to think that I was mistaken.
After looking through the provided documents, I am sure that is the part I need.
I'd love some suggestions for either an alternate part number or a reliable supplier.
Smoke_Jaguar
I just use 1/8" air brake or fuel line connectors in a pinch. Cheap and can be sourced locally if you know your way around the auto parts shop. PDS lists the 10 pack for $9, so probably around $40 with shipping. If it is in stock.
  • I Appreciate You
