Have two early Mimaki UJF-3042 s (non fx) They were set up for LH-100 rigid inks I have gone thru both machines cleaned & replaced filters / ink lines heads , etc . I need to get them working with the LF-140 ink set but looks like they were designed before LF 140 inks came out . Everyone says they should work fine with the new ink set - Manuals and firmware have nothing other than the LH-100 inks . Plan is to order a set of chips for LH-100 s and use them on LF-140 carts - Machine should think its using LH-100 ink and be happy - I have 600ml set for bags and a set of 220ml blanks
Has anyone found a workaround for using LF-140 on the older UJF-3042's , Is there a better way to do this ? Many thanks .
