Mimaki UJF-7151 plus Unresponsive
Discussion in 'Mimaki' started by Smartish, Jan 28, 2020.
  1. Smartish
    Smartish New Member
    2
    Jan 27, 2020
    Austin, TX
    Our 7151 recently started acting up and is now basically unresponsive when any button is pressed. I came into work on Monday and the screen displayed the "power off; press enter key" menu. Seemed frozen but began to work briefly. I was able to print 3 runs. On the 4th, the printer stopped halfway through the job and returned to the "power off; press enter key" menu. I was able to exit the menu by restarting the machine via switch. I restarted the job and the same thing happened. This time the machine froze completely. The machine will not turn off when I hit enter, and I can't exit the menu by pressing the "end" button. I turned the machine off with the switch on the side, restarted raster link, unplugged USB, unplugged power, replugged everything; NOTHING. The menu screen seems to randomly "fix" itself and returns to the main menu after a while, but it is inconsistent and the buttons still do not work. The machine is not recognized in rasterlink. When the menu is frozen, the clock still moves forward indicating a possible PCB failure. I took the menu panel out and reconnected the PCB ribbon cables. Still nothing.
    We currently use RasterLink6Plus v. 1.9 and the V2.60 firmware on the machine.
    We also use a UJF-6042 MkII that is working fine with RasterLink.
    Any information on this issue would be very helpful.
  2. TD Digital
    TD Digital Member
    30
    11
    8
    Jun 1, 2020
    78650
    Can you boot up into FW/Update mode? I would try reloading firmware and start simple by replacing the printer cable. I have seen odd things happen with poor data transmission.
