We run 6 color inks (CMYKmcWW). Missing the Light Cyan.
So, I changed my first ever print head. After it was installed, the test draw looked great. I did all the adjustments (angle adj and back-forward adj). Finished up with those and the test draw was perfect. I finished up real last in the night so i was happy and didn't run a sample run.
Next day, the light cyan was missing in the test draw. Did a standard clean...nothing. Ink fill up, nothing. I double and triple checked my capping alignment. Nothing.
I'm running out of ideas on how to fix this. When i changed the print head, i also changed the Damper and the rubber cap. The ink flowed through the damper after i installed it. I will say, the damper now only has a little ink in the circular area now.
Thoughts anyone?
Thoughts anyone?
