MORE 560 Problems
Discussion in 'Hewlett Packard' started by eahicks, Feb 13, 2019.
  1. eahicks
    eahicks Magna Cum Laude - School of Hard Knocks
    2,500
    356
    83
    Apr 17, 2012
    DALLAS, TEXAS
    Now we are having issues with scratched ink/rubbed ink across prints on the left hand side of most everything we run, due to tension of the take up tension bar being too loose on the left end. So before it can even cure, it's rubbing up against the screws and other crap on the bottom of the curing unit. Looked like head strikes at first , but that's not what's happening.
    Anyone else noticing a problem with the tensioner? Vinyl will literally bunch up under the curing unit, because the left side doesn't pull tight like the right side does. Even if you tape down ONLY the left edge to keep it tight. Today we've rigged a weight on the left side to see if that will help.
  2. Asuma01
    Asuma01 Member
    328
    47
    28
    Nov 19, 2013
    Bend, OR
    560 user here. This is actually a problem I haven't experienced. You should call up HP support. You might have a problem with whatever motor runs the tensioner. I assume you have ruled out that you might be loading in the media crooked or incorrectly?
  3. eahicks
    2,500
    356
    83
    Apr 17, 2012
    DALLAS, TEXAS
    Ha...yeah everything is loaded correctly. it will run for a while then start this problem. You can sit and watch it happen. We'll be calling a tech out I suppose. Just had them out for burned out curing fan motor. The issues are piling up on this thing.
  4. Mike G
    Mike G New Member
    8
    Sep 21, 2017
    Brookfield Ct
    We've had that problem also. It would print fine, then hit and then be okay again. Try increasing the vacuum, it helps to hold the media down while it passes through. You can increase the vacuum while it is running. We usually increase by 10.
  5. Dan360
    Dan360 Member
    486
    100
    43
    Dec 23, 2014
    Ontario, Canada
    We have the same problem, but the opposite side, on our 360 with certain medias. I just pull the media on the take-up (grab it between the take-up core and tension bar) away from the side with more slack (to the right in your case) and that typically evens out the tension, you can see the difference and should be able to tell when it's about even. I have no idea why it happens, I tried attaching to the take-up in many different ways and never found a proper solution.
