Mounting to smooth granite outside
csudman
I have a golf course we're rebranding. They have really nice granite hole markers at each hole. the old logo is engraved into the marker. The plan is to route alumacore into their logo and attach. The granite is a smooth polished finish and I'm conserned about adhesion over many years. Should I use a angle grinder to rough the surface where these will be attached? Planning on using double sided tape to hold and silicone. Thoughts?
Rick
Another choice is to mechanically attach a backer to the granite,
then use the panel with the logo and attach that to the backer
using VHB and Lords Adhesive
Rick
You probably could get away with just
adhesive... granite countertops are usually
epoxied to form a bullnose or finished edge
csudman
That was my thought, but do the have the same supersmooth finish where they are joined?
SIGNTIME
If you're really nervous you can drill with glass/tile drill bits but it will take longer. I would drill with regular masonary bit and hammer drill just test where you wont see (where the sign meets the ground)
Rick
It's rough, but only 1"-1 1/2" thickness is used to bond the surface.
The weight difference of the material you are dealing with is only a
fraction of what granite weighs. And the sign will probably have a larger
area to bond with. I think 1/8" aluminum would be a little more stable.
Moze
VHB & neutral cure silicone or Lexel would be my two cents. You'll need a pry bar to get them off.
