Mounting vinyl with laminator?
Discussion in 'Roland' started by Illuminated, Dec 19, 2007.
  1. Illuminated
    Illuminated Member
    207
    Nov 7, 2007
    Pittsburgh Pa
    Question I am printing some 18x24 photos to cal vinyl and was having a hard time mounting them to an 040 styrine ...it seams the ink it too fresh and softens the vinyl making it hard to mount...
    My question is how long should i wait before attempting to mount the print???
    I think my problems are due to me tring to rush the job and mount too soon.. any insight ....I have ran a laminator before but dont remember it being this difficult! I thought I would put this up before I chuck another print in the trash....
  2. Bobby H
    Bobby H Very Active Member
    2,182
    187
    63
    Feb 4, 2005
    Lawton, OK
    What kind of printer (and inks) are you using? Certain ink and material combinations require longer wait/cure/dry times than others. You might be waiting as little as an hour for one kind of print and waiting over a day for another.
  3. Illuminated
    Illuminated Member
    207
    Nov 7, 2007
    Pittsburgh Pa
    Roland sp 300 eco max
  4. cfbeagle
    cfbeagle Member
    148
    Maybe it is just me but I have no luck mounting unlaminated vinyl with a laminator, If I laminate the vinyl first then mounting it to the substrate is a breeze.
  5. Stan B
    Stan B Guest
    we mount unlaminated vinyl with laminator very often. Sometimes even right after printing with very heavy ink deposits. The trick is to be very careful and slow then removing 1/2" of the liner and not to stretch the vinyl. We put vinyl up-side-down and put the substrate over, not touching the adhesive, position it precisely and then press the substrate to the adhesive part and put it to mount. Works well 99% of the times
  6. Illuminated
    Illuminated Member
    207
    Nov 7, 2007
    Pittsburgh Pa
    sorry maybe im misunderstanding you.. are you saying that when you run it through the laminator the sub is on top???
  7. MobileImpact
    MobileImpact Active Member
    759
    we mask the first 6 inches or so of the print to make it rigid. This helps us get the laminator going. Other then doing that, all you can do is wait a day or so for the print to solid back up a bit.
    Kevin
  8. Stan B
    Stan B Guest
    no, we feed regular way,
    but snap a substrate over a strip of adhesive vinyl to attach it together
  9. Carl Crabtree
    Carl Crabtree Member
    226
    Sep 26, 2007
    Tennessee
    Are you using a cold laminator? We print with a mutoh value jet and can mount the prints within minutes after printing. Are your heat settings high enough on your printer?
  10. Illuminated
    Illuminated Member
    207
    Nov 7, 2007
    Pittsburgh Pa
    Stan b gotcha... carl... cold mount but I have heat its just not on... The ink is dry to touch but vinyl is to soft to mount...I think moble impact said it best, it needs to "solid back up" I printed 2 last night and came in and mounted them they went down perfect then the fresh prints wouldnt mount "f"ed up 4 in a row ...
  11. petepaz
    petepaz Major Contributor
    4,340
    82
    48
    Feb 14, 2007
    NJ/NY/PA
    we do this all the time and about 98% ok
    we use a hinge to get it started and then pull the release liner as it goes through the laminator
    i am sure there are some threads of this some where on this site
  12. Illuminated
    Illuminated Member
    207
    Nov 7, 2007
    Pittsburgh Pa
    Yeah I got the hindge straight and my mounting technique is good but how long do you typically wait from when the print comes off the printer to mounting it with the laminator? I assumed I could do it directly but I think I need to wait a while
  13. WB
    WB Active Member
    843
    2
    18
    Feb 9, 2006
    Canada
    If I'm in a ruch I'll pre mask the whole thing just to make %100 nothings going to shift or wrinkle.. if it's been out for 24hrs no pre-mask needed. All depends on the ink load really..
  14. Illuminated
    Illuminated Member
    207
    Nov 7, 2007
    Pittsburgh Pa
    does anyone apply application tape with a laminator??? on larger runs..
  15. Bogie
    Bogie Very Active Member
    1,972
    The easy fast way is to lam the vinyl with your squeege, then squeege it onto the substrate. 3-4 minutes setup at the max. If you just want vinyl on the substrate, wait a few hours or maybe you need to drop your ink and raise your temps a little.
  16. petepaz
    4,340
    82
    48
    Feb 14, 2007
    NJ/NY/PA
    i would say i probably wait about a half hour approx.
  17. javila
    javila Active Member
    843
    The trick to mounting unlaminated prints is to not pull alot of the backing off. Maybe one or two inches while it sits on the roller, anymore and it's stretch city.
  18. petepaz
    4,340
    82
    48
    Feb 14, 2007
    NJ/NY/PA
    very good point
    and don't rush go slow and smooth
    but also try not to stop in the middle
    and be carefull at the end sometimes the tail end
    can wrinkle or fold over as it comes off the roller
    i usually get my finger nail on it to hold it to the
    roller as it finishes
  19. Illuminated
    Illuminated Member
    207
    Nov 7, 2007
    Pittsburgh Pa
    Thanks for all your time and imput on this one! But I Let em sit and had a fan on them and came back and ran all 26 prints without a problem so I guess I just need to give em some time!
    it sucks when you start your day off and your destroying stuff and filling up your garbage$$...
  20. TheMattMan
    TheMattMan Member
    120
    I keep rolls of 4" transfer paper around and just tape the lead edge and apply it like you normally would.. works 100% of the time.
