Jthompson Designs
Looking for help with my Mutoh 1304, I replaced two of the 4 ink ID boards, other two look fine, I kept having issues where the printer would error "NOT ORIGINAL INK" after removing the cartridge and replacing it a few times it would go away.  I found there were pins that were bent on two of the boards, after replacing the message does not go away no matter what I do. Any help would be appreciated. I do run best jet bulk inks. This started happening after a banner run of 15 banners, the next day I turned the machine on and since then the machine has been down with the issue.
I have heard there is a bypass to the smart cards but not sure or who to talk with to eliminate this issue.
