"So they may boast it was hours quicker using the 2 separate machines but really that's just a...Myth.
And I consider that myth...Busted!"
Sorry, but I am missing this, where have you demonstrated that it is not quicker on two machines?
You say that it takes more interaction but I dont see where you busted the 'myth' on capability.
My point being it may have been quicker by a few hours in actual time, but the Roland guy was off doing other jobs all the while the Mutoh was being attended to.
In fact he could have scheduled the VP to run overnight, thereby making any speed claims redundant.
I'm just making a point that counters their claim - I don't think it matters much whichever way you do it.
I print and cut on seperate machines now.
As Graphics2U says, when you have to laminate in between, then the advantage of a printer/cutter is lost.
Comparing Speed is one issue, comparing 'profiles' is another issue that is not related to speed or the machine itself.
No, but they are comparing the finished output.
They put up samples of the finished prints presumably to show the quality of the Mutoh prints comapared to the quality of the VP.
I think they forgot to look beyond the 720dpi rez and look at the actual printed image. It's shockingly bad.
Certainly unsellable.
Which begs the question - how can Mutoh get it to look so bad?
It's not hard to properly profile a machine - I do it myself and get perfect colors and gradations.
So it leads me to believe they are either not even trying to provide usable profiles with their machines, or their machine/rip combos are incapable of being profiled.
It's not the first time I've been lead to assume this either - after seeing a demo of the VJ-1204 I came away unimpressed by the colors. And the distinct lack of reds in their printed color swatches.
I'd like to be proven wrong here. Seriously.
I like the VJ1304 for it's compactness and speed. And I already have a Graphtec 7000 cutter with Reg mark sensor.
But I've yet to see a print sample from one that I would call good.
RandyA do you make your own profiles for these machines?
