I have a mutoh vj1324. I flushed the print head in the lapse of ordering a new head and now the print head tries to print but will not lay any ink. It works on clean. I was told that the f2 fuse was blown.. I cannot find an f2 fuse on this board? am i missing it or what?
All the pics I saw doesn't look similar tommy board I see f3 and some more and f1 on top offspring head but still no f2
Not able to see anything could be the fuse blown or other reasons. If you did not take care this issue well, you might blew other components as well including the new expensive printhead. Please consult with the company who you purchased it from or have someone to come out to properly diagnose it.
You might still have factory warranty left. The dealer is obligated to install the parts under warranty. The Mutoh warranty for 1324 is 1 full year. Any Mutoh parts installed by a non-certified technician will not have any warranty. The warranty is only apply to the first owner of the equipment and is not transferable.
Premier Colour
714-668-9200
Did you find this. The fuse can be changed if you know what your looking for. There is a fuse that allows power to the head so it can fire. Normally they will be popped if you unplug power and do not hold down the power button for a few seconds to discharge any power in the capacitors before you start working on it.
They are hard to get to but look like a small rectangle cube. Black end goldish center. Shoot me a pm i may be able to find pics of it i have some left over. I think i have some pics of the location of this exact fuse as well.
Link to buy http://www.mouser.com/Search/Produc...0MRvirtualkey57610000virtualkey576-0449.750MR
MFG# 0449.750MR
mouser # 576-0449.750MR
Image of fuses below.
I know this is a really old post but did you ever find the F2 fuse on your board? I cannot find it I found everything except for the F2 fuse. I’m having the exact same problem you had. Please help!!
