n00b questions about flexisign 8.0
Discussion in 'Newbie Forum' started by hellfire_studios, Aug 9, 2008.
  1. hellfire_studios
    hellfire_studios New Member
    13
    I am very new to the vinyl cutting business. Only done a few things for people. I have a few questions about flexisign 8.0.
    I am trying to use a font called Tattoo Ink. I found it through google and have been using it for my personal logo. But some of the letters are not cutting all the way out. Like the font isn't setup perfect for vinyl plotting. Is there a way I can edit the font to work correctly or a way I can go into flexisign and correct the problem on the certain letters that create the problems?
    another question. I see you can open regular *.jpg files in flexisign. Is there a way to open a jpg of an image you want to cut and convert all the lines to work?
    Thanks in advance for the help.
    Josh
  2. Gordy Saunders
    Gordy Saunders Member
    423
    You can edit your letters, but you have to become familiar with the tools in the program.
    You can also trace jpeg. But I've always had to do cleanup work after and auto trace.
  3. hellfire_studios
    13
    How do you run auto trace? I am very new at this.....
    also what is the best way to clean up this font?
    Any help would be awesome. And thank you already you have helped.
    Josh
  4. Service Sign Co
    Service Sign Co Very Active Member
    2,311
    Nov 9, 2006
    Southaven
    The first letter is the uppercase, looks like it would be a little more tedious to weed
  5. Gordy Saunders
    423
    Go to Bitmap - Go to Vectorize - Click on autotrace
  6. hellfire_studios
    13
    yeah that is exactly the problem I have had with it. how can I change the letters that have that problem to look like the second one you have listed? can you go edit the font and do that or will I have to change it every time I use that font...
    Josh
    oh and to gordy thanks I will give the auto trace a shot.
    I had one more question. If I wanted to layer my logo say with red in the middle of the font and white on the edges....I mean like so that the letters are red with a white outline...is there a way to go in on flexisign and give it an outline like that?
    Josh
  7. Schultz Designs
    Schultz Designs Member
    164
    check the offset of you're blade if shapes do not cut 100%
  8. iSign
    iSign Major Contributor
    13,027
    31
    48
    Nov 29, 2003
    Kahului, Maui
    your boss should really train you on all this basic stuff
  9. Service Sign Co
    2,311
    Nov 9, 2006
    Southaven
    Use the lower case to change the font style,it's the caps Lock key, use the help menu in flexi
  10. coyote
    coyote Active Member
    804
    1
    18
    Nov 13, 2007
    Baltimore MD
    Buy the Mark Rugen book-Flexi, The Power is in Your Hands- He sells it on EBay and it's a good $80.00 investment. Most of your questions will be answered and you'll save a lot of time. You can teach yourself how to use it with your projects-
    Carol
  11. hellfire_studios
    13
    Thanks for the advice on the font. I figured it out last night after I replied that I just needed to do it lower case.....worked great cut perfect no problems.
    As for the person that said my boss needs to train me....I have no boss. I bought a plotter for home/painting needs and just decided that I might start doing stickers and banners for friends....
    I am using my plotter mostly for airbrush stencils....I am a custom painter out of Tampa, FL. But the software and application techniques are my biggest problems....and besides this is the newbie forum right? I figured these where valid questions....maybe I was wrong?
    thanks for all the help.
    Josh
