NEED HELP PLEASE! puzzled by the simple things
wabam
Okay so, I was out sick for a few months. I come back to all of my settings changed. No biggie...except one! In Illustrator and Photoshop all of my art boards have these annoying trim marks in the corner. It wouldn't be an issue except they are printing and wasting material. My question is... How do I turn them off and make them go away forever? Please help, I know it's probably something simple I missed or slept through the first time I learned it. This is driving me NUTS!!! See the attached image for exactly what I'm talking about. Thanks in advance for all your help.
The Vector Doctor
Chief Bezier Manipulator
Are you sure that the problem is not something in your rip or print software? The sample you provided is a screenshot that appears only when you adjust/create artboards. They disappear after they are set.
a77
The trim marks you are showing in that screenshot are outside the artboard... and they don't stay when you get out of "editing artboard" mode. Are you sure they are showing up in your pdfs?
edit: sorry... vector doctor got it already
x2chris7x
If you are saving out as a .pdf, when the "Save Adobe PDF" box comes up, click "Marks and Bleeds" in the list on the left. On the "Marks" section make sure no boxes are checked.
shoresigns
To be clear, the trim marks you see when you're editing artboards are an on-screen visual indicator only. They do not get printed. If you are getting printed trim marks it's probably due to having them turned on when you export to PDF, but I believe they are normally off by default.
xxaxx
+1 to this ... Would be my guess as to your issue.
wabam
I usually save as an .eps but, they are showing up on .jpeg, .tiff, .pdf as well.
wabam
Usually save as .eps
T_K
I have printed in pdf, eps, tif, and even jpeg in the past. Those trim marks do not show up in my prints. I can tell my rip software to print marks that look just like those, but it's not coming from illustrator.
wabam
This is what prints. The dot should be there but be close to the blue. The trim marks shouldn't be there according to all my settings.
The Vector Doctor
it is not a setting in Adobe software. Compare the trim marks on this image and your first one. They are farther away from the corners on this second photo. And as mentioned before that first screen capture is only for setting the artboard. They are not trim marks and simply disapppear when you exit out of that function
wabam
I can also tell my rip software to make marks like that but, that option is set to NO marks
wabam
Seems to only do it in one of my two versions of Roland Versaworks. Same file doesn't print the marks. CAN NOT find the setting difference!
wabam
OK. It was some random setting in Versaworks. THANKS to everyone for your helping me narrow down and solve this problem. SIGNS 101 people rule!:signs101:
