gabagoo
To make a long story short...the customer screwed up and now I have to save his azz so I can continue to do work for this very large customer.
I have petG paper holders on an info board and I need to take them off as the double sided tape is to wide and making slipping paper in to hard. I know I can take the holders off but the double sided foam tape leaves about half of itself in place. I have laminate on the prints so I was thinking maybe spraying WD40 on to loosen the paper and adhesive for easier removal. Any other ideas if that does not work? I don't want to damge the laminate as I have to put down thinner pieces of tape to fix this nightmare.
....as you say if there is damage I can put down a square of white to hide it...but it will be obvious.
