been around computers probably a lot longer then most of you. got my start on them in 1972, YES 1972!!!!! air force had this monster(IBM 1050-2) that took up 2 regular rooms, had to be climate controlled because of the heat it created, had a wopping 640 K OF MEMORY)))) instead of floppy discs, or or jump drives, it has 2 ISA DRUMS!!! bout 6-8 foot long, and to change them it took an overhead crane. all info was put into this via keypunch cards that someone had to write, then send to keypunch then put into the keypunch card sorter. such a technological marvel that was.
then i got my 1st PC 386DX40, 4 megs a ram.....hada friend of mine who was computer programmer..........gave me a tidbit of advice which i seemed to have used since then. YOURE COMPUTER ...........only needs to be as fast as your slowest peripheral. so iam sorta lost with need for faster....cause you aint gona get anymore done until the printer gets faster.............
Because of that issue with peripherals - I just put together a RIP for Caldera running Linux (or Onyx) but also purchased Windows 8 to see what it would do as a Workstation. Overall I am quite happy with the unit, though I have yet to receive Onyx - they sent Poster shop instead of the APPE Adbe RIP version.
The idea goes this way -
1.)with large amounts of RAM there is an increased likelihood of a memory error which will bring the system down - Using ECC RAM provides a parity check giving the memory a 2nd chance to save itself. I went with it.
2.)ECC memory requires a motherboard and processor to support it - I saw too many issues with Asus so went with the SuperMicro, I would have liked to go with a Gigabyte motherboard with backup ROM but could not find one meeting the ECC RAM requirement.
Issues arising from the SuperMicro motherboard - the dual network cards were to new for the default Caldera Color RIP, rather than compiling for them I took the lazy way out and put in a Intel Gigabit PCI card I had already. On the plus side the integrated networks cards are apparently 10 Gigabit capable if you happen to own a 2000.00 network switch which will probably be 298.00 in a years time.
Xeon Haswell 3.5 ghz processor seems to claim something like 3.7 ghz starting up. Mine included built in Video. Windows 8 processor performance was 8.1 but only something like 5.1 for integrated Video, which may still be fast enough for static images. Upgraded to 8.1 and it shows 8.3 Processor experience but had to go online to figure out how to get the info as they deleted the program from Menu.
Issue arising from integrated video - Under Caldera Linux it only displayed at 1280x1024 . To match my monitor 1980 x ? . I added in a older NVIDIA card that cost less than $100.00 a year or 2 back and ended up with higher score (around 6) but mainly the ability to run the 27" monitor at full resolution and a 2nd if I choose. NOTE - you should be able to run 2 monitors with the integrated video under Windows, but if you want performance the motherboard should allow 2 high performace Video cards supporting up to 4 monitors. And if the videocards break you can use the integrated one to run up to 2 monitors in Windows.
Powersupply - was purchased oversize to run high performance Video Card if needed.
Case - is great but way over size, as I use a SME Linux Server so really only need 1 SSD in the system. I think I will like the air filters but sure would like a smaller case.
RAM 2 x 8GIG strips (1 seems to be all that is needed with Caldera RIP) Will allow up to 32 GIGs . I went with the in stock Kingston against better judgement as I have had issues in past and the fine print of their lifetime warranties wants a bill of sale which a few years later can be rather a issue. Will be throwing a copy of all invoices into a packing slip and attaching to computer in case of warranty in next 3 years.
Computer is solid so far - no glitches, I used separate drives for the RIP and Windows Install - I did have it refuse to clone backup with opensource program redobackup 1.04 but it may have been a faulty CD as it backed up fine with redobackup 1.03 cd.
Windows 8 pro vs Windows 7 is no biggie just go to Ninite .com and add classic start menu as well as the other must have accessories in 1 auto install. I did not appreciate NewEggs Windows disk, the serial number is like 25 digits long and I could not read it on the colored background with a magnifying glass, I had to get out my trusty 10x printers loupe, also I found Microsoft does not support Windows OEM purchased through Newegg better might be to buy direct from Microsoft so they will talk to you when you call them - in my case it was because initially I read another number as the serial number. Other possible benefits of Windows 8 - 3D printer driver, maybe a touch screen?
Monitor 27" LED but last monitor a 28" LCD was just that much larger - will be looking to other vendors for a 28" LED if one exists - this seems to be the sweet point in monitors before they suddenly triple in price to the next size larger.
Items purchased follows.
16 Gigs ECC error correcting RAM 1600 speed in 2 modules of 8 Gigs so it can go as high as 32 , hope for Crucial brand as I have had a few Kingston items fail , but I see its dropped off my order in progress as out of stock.
Intel Intel Xeon E3-1275V3 Haswell 3.5GHz LGA 1150 95W Quad-Core Server Processor BX80646E31275V3 Item #: N82E16819116908
This processor has onboard Graphics Card which should save buying a Graphics card as the Mac Mini uses no graphics card from the looks of the specs.
SUPERMICRO MBD-X10SAE-O ATX Server Motherboard LGA 1150 Intel C226 DDR3 1600 Item #: N82E16813182831 as it is capable of using the error correcting RAM and the Xeon revision 3 processor base (1150) drawback is only 1 year warranty but could not find a server motherboard in other brand that had 1150 base and feature set I desired. Features dual LAN connections as well.
Antec Three Hundred Black Steel ATX Mid Tower Computer Case Item #: N82E16811129042 , has air filters - will be a nice change, I hate what computers look like inside after a year, have to keep a sticker on them for when last cleaned, like an oil change for a car. Went at last minute instead with 1 x Rosewill R5 Black Gaming ATX Mid Tower Case, comes with 2 x front fans, Fan Controller, USB2.0 & USB3.0 front ports, filters because of mention it supported 2.5" drives, turns out the 3.5" caddies are all drilled to take the 2.5" drives as well -great for SSD's
CORSAIR Enthusiast Series TX850M 850W ATX12V v2.31 / EPS12V v2.92 80 PLUS BRONZE Certified Semi Modular High Performance ... Item #: N82E16817139029 (not listed as a server motherboard, hope that is not a cable issue, is 5 year warranted, is large for these low power components but would allow me to add a potent Graphics card if onboard isn't powerful enough.
SAMSUNG 840 Pro Series MZ-7PD256BW 2.5" 256GB SATA III MLC Internal Solid State Drive (SSD) Item #: N82E16820147193, minimum recommended size by Caldera but lots for a workstation as we use a separate server. I have a spare 1 terabyte Western Digital black - year warranted drive here so would try both ways to see if any benefit from having a SSD other than startup, I know its the way to go for running several programs.
Windows 8 Professional - to test Onyx and eventually use in the Graphics Workstation I intend to build as hopefully will be going with Caldera 64 bit .
27" monitor Viewsonic- to keep track of queues, and display. One drawback discussed with Caldera being no monitor calibration utility in Linux, but can calibrate on a nearby PC adjusting hardware then plug into Caldera computer. This is one instance of Mac having monitor calibration software .
Enjoy
Ken
