Need to manipulate a PDF in illy
Discussion in 'Adobe' started by Angela, Nov 8, 2010.
  1. Angela
    Angela Member
    224
    Oct 7, 2010
    Temecula, CA
    Hello,
    I need to manipulate a PDF in illy. I have placed it, flattened it, rasterized it, and to no avail. Is what I need to do even possible? Any feedback is appericiated.
  2. HaroldDesign
    HaroldDesign Very Active Member
    1,367
    Sounds like the elements were flattened prior to it getting to you. If in outline mode you don't see any vector elements, you have nothing to work with.
  3. HulkSmash
    HulkSmash Major Contributor
    8,159
    140
    63
    Sep 10, 2010
    Denver.
    if by illy you mean illustrator.. you can't edit a flattened file..
  4. The Vector Doctor
    The Vector Doctor Very Active Member
    3,496
    144
    63
    Aug 15, 2005
    Ohio
    Be more specific. What do you want to manipulate? Do not rasterize, that turns it into pixels which is not vector
  5. jc1cell
    jc1cell Active Member
    596
    Jun 11, 2007
    76137
    If the PDF is originally from a pixel file you will not be able to do any editing in Illustrator. Play around with it in Photoshop if its only text you will be changin.
    jc
  6. BlueFishDesigns
    BlueFishDesigns Very Active Member
    1,714
    Aug 21, 2006
    Huntsville, AL
    If it is a vector file, when you click "Place" and it wants to know which file to place, in the bottom left corner there are 2 boxes: Link and Template. Make sure Link is checked and not template.
    After you find the file, a Place PDF window pops up. I like "Art" for the Crop To option. Maybe mess around with that.
  7. Angela
    Angela Member
    224
    Oct 7, 2010
    Temecula, CA
    I believe it is flattened already. Thank you all so much.
