Need to PRint a Good Screen
joeutut
I have an HP 3500 CP with HP UV Inks installed. How can I get this machine to print me a good screem? Shadows look very grainy.
Any help is greatly appreciated
Joe
HaroldDesign
I no longer use Wasatch, but I did use it extensively for a few years. What line-screen are you printing? anything below 5% tint will turn into a scum dot.
joeutut
I have it set for precision stacastic at the lowest setting, "1". Is there a better screening I can use?
HaroldDesign
I used stochastic when ripping out of Wasatch to a CTS, but when printing film the HP print didn't have enough density to get a good screen without playing the over-exposure game. I did however get good results using the ellipse at 55 or 65 lpi. It takes a bit of setting up, and I wish I could remember what angles I used for each color, but if you're going to produce one color use a 52 degree angle.
HaroldDesign
No problem. If you have any more questions be specific, as I haven't used Wasatch in a while but I think I'll remember more the more specific you are.
joeutut
Ok, I went to halftone properties and set it from the list to PostScript Screenning then the Dot Shape to Simple Ellipse. By default the frequency is at 55 on all colors. When I did the settings I just wrote, the shadow area looks more grainy. Am I hitting the correct area to adjust?
HaroldDesign
I think you're on the right track. What exactly do you mean "shadow" areas? Areas with tint, or some sort of gradient? Another thing I remember is making a configuration that would print black only at a higher ink%. The files I ripped through Wasatch were already separated through a pdf file printer out of Illy. I then ripped each color to the configuration named for that color (although the only difference was the angle).
joeutut
What I have is a 4 color image with a black shadow gradient. Here is my process, Illustrator File save as an eps, open in Wasatch, Rip & Print.
joeutut
I really do not know but I just think this printer should do better, I am not sure. The file I am playing with was sent to me but it is typical of the results I get. I am outsourcing this file to a printer I use regularly who always is top notch so I can see what it looks like with someone who knows what they are doing and compare to what I am getting.I really can't thank you enough for sticking with me but I have to go. I will repost again with better info and more knowledge. Thank you so much for your patience you gave me more ideas to tinker with.
HaroldDesign
You're welcome. I get lots of help on this forum and try to give it back - that's what I love about Signs 101 (and the brutal entertainment). One last thing - if you can rasterize that portion of the art in Illy give that a try.
bbeens
Joeutut-
Just to be clear, you are attempting to print with just K ink for film production and not printing in a CMYK mode - correct? The driver for that printer is rather limited in the options available. I haven't touched any HPs from that era in a while. What resolution are you printing at 300dpi or 600dpi? If you can get away with a lower LPI I would suggest trying that - theory being that larger halftone dot will help hide said graininess.
Bryan
Bill Modzel
I've tried to get a good dense print on film on my HP5000 and have never come close to a solid positive image. Both pigment and dye inksets left much to be desired.
I think you really need a piezo printed like the Epsons to get a good screen print film.
