Nervous
Angela
I am just getting into logo design, which you will be able to tell by the art work I am submitting. I am hoping for some friendly advice on where to go next or if it should go to the recycle bin instead. Please be gentle(ish)
  • xit telecom.pdf
fmg
You have a good foundation to build upon this.X is too big and the effect is not needed.
bob
It's very, ah, institutional looking. It has all of the excitement of a freeway off ramp sign. If that was the look you were going for, you've achieved it.
Regardless, lose the gradient.
Kaiser
I like it. Its a good foundation indeed. Here's a cleaner suggestion which can be used mono. Hope you like it ;)
  • xit telecom2.pdf
SignManiac
I'm sick so I could use a diversion. Another way to play with it.
WI
I always try to design logos so that they work in black and white, period. No grey, no gradients, just black and white. Once you get that established, then start adding color. Your concept is good, it just needs balance and some management of negative space.
Also, Arial?
I know I'm being a snob here, but seeing logos made with fonts that ship with Windows upsets me. There are a million sans-serif fonts out there, and most of them are better than Arial. Avenir, Avante Garde, Century Gothic, Gotham, Folio, Interstate, Helvetica, Franklin Effing Gothic.
Check those out. You might be pleasantly surprised.
JTBoh
I sell signage and signage accessories.
actually... OP's is my fav.
Although it looks like if you add an e and shrink the x, you have an exact replica of an exit sign. Trick is to still imply the exit sign while not making it look exactly like one, you lose the uniqueness of the sign if you simply recreate something. May want to change the font for everything, or add a slight right-side convex vertical to the "IT", or something.
JTBoh
ps - couldn't resist ;)
John Butto
JonMASigns: lets see what you would design, you give a lot of advice but never see anything except some bad copy in front of a Lord of the Rings guy. So, "put up or shut up".
redbarn
LOL! Yes, many people do with no schooling or experience. Some of them are really successful. Don't be the hater from hateville.
Angela
you can't just get into logo design. It's something you really need to learn and research on.
Thank you all so much. You were all very kind and extremely helpful. I will work on this and resubmit.
Might I ask what program most of you use when designing a logo? And any recommendations pertaining to what Coloradosigns says?
