Network not networking
Discussion in 'Computer Hardware' started by Accelerated Graphics, May 9, 2007.
  1. Accelerated Graphics
    Accelerated Graphics Active Member
    887
    1
    18
    Jan 11, 2005
    Burleson
    I have a my computers networked and 1 day 1 of the quit netwotking, I pluged my laptop into the cable and it works fine, I bought another ethernet card and still won't work, It says it aquirring address.
    Any Ideas.
  2. TresL
    TresL Very Active Member
    1,010
    Oct 24, 2005
    Guess #1
    Whatever you have serving up DHCP is out of addresses.
    or you need to hard code an IP on the PC not working if you don't have anything serving up DHCP....
    Does the working laptop have a static or dynamic ip address?
  3. Sites&Signs
    Sites&Signs Member
    186
  4. Techman
    Techman Major Contributor
    8,520
    8
    38
    Jun 24, 2003
    michigan
    HUH???????
    Anyway,
    When a machine stops interacting within the network there are a few baisc things to look at.
    Firewall. Network name and a few other basic items that all must be in order.
    Too much to poast about in one post.
    If it worked one day,, then it should work again if the settings are right..
    Anyway, Does the LED lights luminate when you plug in the cable? Check to make sure any firewalls are not interfering. Make sure you have sharing set up. Make sure the network name matches.
    How many machines are oon the network, Are you using a hub, and a router?
