Networking with Flexi...
Discussion in 'Flexi' started by Joseph Dunkle, May 23, 2006.
  1. Joseph Dunkle
    Joseph Dunkle Active Member
    518
    First off I have read the other threads about networking and Flexi and have some questions that are not really the same, So here I go...
    This is what I have:
    1 laptop with windows xp
    1 desktop with windows 2k
    1 copy of Flexi 7.5v1 Starter
    1 Peice of crap plotter
    3gigabyte/sec cable internet connection
    wired/wire less network.
    Now what I want to do:
    What I invision is to take the desktop and make it a stricktly a production only computer, no email, no internet browsing. It has two 80gig hard drives. one for programs and one for files. I want to be able to axcess these files from anyware with my laptop (I mean ANYWARE) and when I am at the shop and it is time to cut I want to beable to send files to the production manager on the desktop from the laptop or if not possible or just too complicated just open it up on the desktop and cut from there.
    My question to all of you wonderful folk is how do I accomplish all of this with one copy of flexi? I use Corel 12 to do all of the designing on my laptop and I can already save it to the desktops file drive when I am in the office. I don't know how anything in flexi works except how to press the cut button for the most part.
  2. WVB
    WVB Very Active Member
    2,749
    Most likely you will not be able to due to the dongle issue. I would install flexi on your desktop and cut it with it. You may access your desktop from anywhere with software such as PCAnywhere, MyPC.com (I think thats it), set up a remote desktop via windows. WinVNC may work for you (frreebie).
  3. Joseph Dunkle
    518
    I read some of the other articles on running flexi on a network and flexi says you can run it as long as the dongle is plugged into one computer and you can only open flexi on one computer at a time
  4. WVB
    2,749
    Correct. So you would not be able to design/send to cut via your laptop to your desktop machine at the same time. So you will have to PC Anywhere into your desktop machine via laptop. (Hopefully you will have Flexi already open on desktop) and command your desktop via laptop remotely.
  5. Joseph Dunkle
    518
    Oh this is gonna be fun... I downloaded the program and it seems to work pretty well
  6. jayhawksigns
    jayhawksigns Very Active Member
    1,209
    34
    48
    Jan 8, 2005
    Kansas
    Joseph-
    Install the full Flexi setup, with Production Manager on your desktop, and just the core Flexi program on your Notebook. This gives you some options.
    1. You can keep the Flexi dongle with the notebook, that way you can use Flexi anywhere without needing an internet connection. And when you have a network connection to your notebook at your shop you will be able to load production manager on the desktop and cut as needed. The PM will see the dongle on the notebook and load.
    2. Or you can leave the dongle on the desktop running production manager and use a remote access software like PCAnywhere or Radmin to access the desktop computer and work on it remotely, which I wouldn't recommend.
    If you want to access your files remotely, going with something like the first idea I listed, you can setup an ftp server and access the files remotely.
    I have been toying with trying to get a VPN setup with our shop and my house, wanting to find out if our dongle on our PM would let me load Flexi over the VPN connection, if it would that would be another option for you as well.
  7. mark in tx
    mark in tx Very Active Member
    2,081
    Oct 25, 2005
    Harker Heights, Texas
    You should be able to have the production manager running on the desktop, with flexi itself running on the laptop. The user manual has the basic instructions on how to do it.
  8. Joseph Dunkle
    518
    Okay folks, I have the laptop saving to the desktop and I can controll the desktop from the laptop at the shop. Now I am having a problem getting my corel files into Flexi, I have tried CDR7/8 cmx, ai, eps, and a couple others and the only ones I can get to open are the cmx and there are extra lines cutting the letters in half.
  9. WVB
    2,749
    I have issues with opening Corel files within FlexiPro 7.5. However, Illustrator opens them flawlessly. Are you using the import or the open command to open Corel/Illustrator files?
  10. Joseph Dunkle
    518
    I don't know wha happened to my post that I put on here last night but;
    I have tried to import and open. I have also figured out the lines problem. I have tried every thing.
  11. WVB
    2,749
    Have you tried to save as an older version of Corel?
  12. Joseph Dunkle
    518
    I have tried corel 7 and 8 since those were the two lowest with no luck
  13. Greg987654
    Greg987654 New Member
    1
    Flexi networking
    Go to www.logmein.com and use their free software. Set up the desktop as the base machine with the dongle. Use the laptop to connect with the desktop via the internet. When connected, the laptop takes over the desktop machine and can run anything on the desktop.
    We use this method to design from home and be ready to print first thing when we come in. Works great.
  14. Techman
    Techman Major Contributor
    8,520
    8
    38
    Jun 24, 2003
    michigan
    SAve your corel files as CMX.. flexi will have no probs with that file type..
