never saeen this tunneling before
Discussion in 'Digital Printing' started by gabagoo, Nov 5, 2012.
  1. gabagoo
    gabagoo Major Contributor
    5,724
    105
    63
    Oct 10, 2006
    Vaughan, Ontario
    I laminated 5 sheets of these saturday morning. each one is about 45" x 90" and I used arctic write on erase laminate on a proveer matte truestock (avery) calenedered vinyl.
    The pic is of the top sheet with 4 more below. the 4 below are fine and after my heart seizure upon seeing this I determined it was not the laminate lifting off the vinyl but the laminate and the vinyl lifting off the backing paper.
    I have it set to be applied to a piece of coro and I think it will go down OK. I ran the sheet through the laminator again to reflatten it and it did nothing and came out looking like this again, although saturday when I laminated it looked OK.
    This is weird.
  2. SIGNTIME
    SIGNTIME Active Member
    663
    14
    18
    Aug 13, 2012
    NY
    looks like they were folded or something does the vinyl have an air release liner?
  3. MikePro
    MikePro Major Contributor
    4,974
    235
    63
    Feb 3, 2010
    Racine, WI
    too much tension on the laminate feed-roller?
    my best guess, would be the laminate was stretched prior to bonding with the print and is trying to shrink back, taking your print with it.
    If it's just curling off the backing paper, then you might be ok and it could apply just fine with a little extra love & heat.
  4. petesign
    petesign Very Active Member
    1,191
    1
    38
    Feb 27, 2010
    Hoover AL
    did you leave it rolled up and masked over the weekend by chance? Ive seen that cause the tunneling you have there.
  5. CanuckSigns
    CanuckSigns Very Active Member
    3,388
    390
    83
    Nov 11, 2008
    Ontario
    This is most likely it, it should be fine once you apply it to your substrate, if you are really worried, after it has been applied, hit it with a heat gun.
  6. gabagoo
    5,724
    105
    63
    Oct 10, 2006
    Vaughan, Ontario
    your all wrong so far.... They laid flat all weekend and they were laminated in sheet form so the only tension was from me holding the piece.
    The vinyl is a 3ml calendered grey adhesived back.
    It only occurred on the last sheet that sat on top of the other 4...maybe the temperature was a bit cold this weekend
  7. ThinkRight
    ThinkRight Active Member
    810
    3
    18
    Nov 13, 2011
    Atlanta Ga
  8. gabagoo
    5,724
    105
    63
    Oct 10, 2006
    Vaughan, Ontario
  9. brush1
    brush1 Member
    287
    old or bad media
  10. gabagoo
    5,724
    105
    63
    Oct 10, 2006
    Vaughan, Ontario
    I applied the graphic and I think there may have been less adhesive in that one area. I would think either there was to much silicone on the backing paper or there was not enough adhesive
  11. synergy_jim
    synergy_jim Very Active Member
    +1. Dry erase lams need light tension on the roller. They also have a tendency to tunnel if prints are not outgassed properly.
  12. gabagoo
    5,724
    105
    63
    Oct 10, 2006
    Vaughan, Ontario
    in this caee it was not the laminate. I have applied them all down and everything is good. I now know the roll is somewhat defective as I have just cut a pile of decals and the same material is tunneling off the edges and there is no lam on it at all. I don't think there is anything wrong with the actual adhesive, but more the backing paper...have seen this from time to time.....need to change suppliers again....doh
  13. gabagoo
    5,724
    105
    63
    Oct 10, 2006
    Vaughan, Ontario
    I am pretty sure this is the Avery vinyl. It is the matte grey adhesived with an 83 pound liner. The 90 lb liner costs considerably more so I see no reason to use it. It is the Truestock from Proveer. I have liked the way it comes off it's backing paper as I find the vinyl ( especially if printed to the edge) to be much more rigid than those that dont have the grey adhesives.
