BigfishDM
let me know on 1 roll of the gloss white backing .
thanks
No problem, can you shoot me your info please. Jcormany@gansink.com
thanks
Define thicker is better? We all know that thinner is better, as in cast, 2m vinyl.
OK, that is one element. Easy to apply. for cheap temporary, short term.
for it's claimed 3 to 5 years, less shrinkage? won't turn brown? weather better than 3M IJ35?
I like to be able to compare apple to apple.
Is white back/grey back referring to the back of the vinyl (clear vs pigmented adhesive) or the liner color?
I tried the "5 Mil BUBBLE FREE GREY BACK REMOVABLE Adhesive Vinyl" in matte finish and it prints as well as IJ35C and 2923EZ matte products. It doesn't seem any thicker than either of these two. The adhesive seems to be as aggressive as IJ35-C. 2923EZ is less tacky at first touch.
Is this supposed to be a 5 year product like the 3M and Avery products?
I also received "4 mil Gloss Laminate with UV inhibitors." Seems ok but I've been using 50" reverse wound Oracal 210 for many years. I don't think I want to give up the grid pattern or reverse winding.
Has anyone else received their samples? Thoughts?
I would like a sample roll of the bubble free white, 1 of each grey and the clear backer please. And if you have a quote sheet on any other vinyl products you offer would be great!
production@decorworx.com
Thanks!
Kevin
I would like to give it a go in our latex. Does it leave residue on the rollers like other cheap vinyls? What type of backer and how thick is the backer?
I have been distributing a 5 Mil BUBBLE FREE permanent adhesive vinyl with a white back for $115 on 54"x150' rolls vs. Everyone else's 3 Mil and even though its selling extremely well I found it wasn't perfect yet. The release liner was a little flimsy and sometimes would have tendency to curl so when I was working on perfecting it I decided to make other versions to compliment it. What has been created came out unbelievably AWSEOME!
PS. The New Gans Ink & Supply wide format website should be up by the end of the month!
1- Does the Gans MAV5 (Matte 5 Mil Perm Adhesive Vinyl) use the same face stock and liner as the MBFAVR-GB that I tried? Do any of the materials still have the "flimsy" liner you mentioned above?
2- Can you share the link of the Gans website? Only site I found is down.
Originally Posted by twister
I too am curious how this works out. I currently use matte Oracal's 3169RA for easy application of yard signs and large 8' x 4' Coroplast/Sintra/metal signs but this may be another option to reduce costs. For those who try it please update this thread with your thoughts.
I would be interested in sample rolls of the 5 mil permanent gloss white w/ grey back in both comply and air release. We've been looking for a worthwhile vinyl for stickers that is easier to handle and install than the IJ35c-10 (given it's thickness it's so flimsy and we don't like taking away from the presentable appearance by taping over them).
Email me at support@dropzonespecialties.com please
Would this stuff be suitable for Perf Cut Stickers? I found a 6mil Matte Material from General Concept 222 it worked great but only comes in 54" and I need 30" for me SP300v. I like not having to laminate simple stickers and decals but all the thinker stuff comes in 54" or bigger. Anyone know a way to cut these larger rolls down? 5mil would work just as good as 6 mil im assuming. I know 3.4mil is not worth my time. Haven't tried a 4mil yet but i believe the results would be the same as the 3.4. Any help or suggestion for a suitable Vinyl that i don't have to lam but still can perf cut thru the backing and is a greater number then 3.4 mil would be greatly appreciated. Thanks
