NEW HP Latex 310/330/360 Printers Firmware
dypinc
NEXUS_00_03_09.3 (6 Nov 2014)
1. Fix for some 79.2:04 and 79:04 system error incidences.
2. Improved long-term curing performance -> HP strongly recommends the installation of this new firmware, even if you are happy with the current curing performance (also included in the previous firmware 03_09.1).
3. Enhanced Internet connectivity performance. Connect to the Internet to have access to the "media presets" repository from the printer's front panel (also included in the previous firmware versions).
Not one word about increasing the Ink Densities.
Davo
Since installing this new firmware we have had a plague of problems... not sure if related though. HP seem to think it's a hardware fault and have replaced half the control boards in our L360 and still no good. HP here down under have never seen these errors before on this machine and are stumped imo. Really poor service as well taking days to get parts in while out machine is down and production is totally halted. I now have a box of spare parts enough to nearly build another machine haha
lerouxjul
Hi Davo,
I have exactly the same problem (error 79.2:04) with the last firmware. When did the error appeared on your printer?
Davo
Pretty much just after installing the new firmware, maybe a day or two later. Then the printer started having trouble resuming from sleep and the psu died.
lerouxjul
When the printer still working with the new firmware, was it possible to print with?
What happens when the psu died ? Printer stay off, no led light ?
Davo
Yes it worked for a little while then it died. The printer would not resume from sleep without crashing the software.
lerouxjul
OK, if I print 10 times, I have to resume printer from sleep 10 times. On these 10 times, I have 8 times perfect resuming without any problem, and printer works good... but I have about two resuming crashing (error 79.2:04) and then, I just have to full switch off the printer (using rear switch) and then full restart printer and then I works correctly.
I feel that I have less and less this error 79.2:04 because one month ago, on 10 resuming times, I had about 5 resuming crashing...
Before replacing PSU, it was always impossible to resume your printer from sleep without crashing, never ?
Davo
It was fine until I started getting these firmware errors, then it would resume fine 5/10 times then it got worse and worse until one day it wouldn't resume from either network or front panel. A whole bunch of parts were replaced, the HP technician diagnosed it as faulty PSU but it was the last thing replaced.
Rodney12
The printer that I am TS is a Latex 570, updated firmware is, STORM_00_07_00.7.
Still boots to the 79.2:04
MonkeyB0y
Good Day
We have spent three days onsite attempting to fix this issue, with no luck, we escalated to HP Australia and they contacted GBU in Barcelona and provided us with a firmware patch, excellent service from their team.
If you are having issues, first remove any chance it is consumables, printheads, cartridges, if you have done this, contact the HP for further assistance.
M
