Christian @ 2CT Media
So $100/L, thats pretty good for this class of machine.
Yeah... kind of. Marketed as cost saving but if you had issues you will know...So by them moving to a separate overcoat ink which they recommend not be used if you laminate, are they admitting to lam issues for the prior gen ink?
More of an location issue thou. You can have terrible support with any big brand if you don't have a good local support.Looks like a nice machine, too bad it's still HP with their horrible support.
You can always buy from BigFish and then complain to him here
There is 9 total, the one you are missing is Overcoat.Has any one seen info on what all the cartridges are? Seems like CMYKLcLm, optimizer, white..what are the other two?
You probably have to request samples from both or go look at them. In terms on technology I think it's quite different but ink may be somewhat similar, the idea at least.I would like to see the difference between the new HP and the new Epson SureColor R5070. Is similar technology.
I believe there is no white option with EpsonYou probably have to request samples from both or go look at them. In terms on technology I think it's quite different but ink may be somewhat similar, the idea at least.
Epson now seems a lot slower compared to these in my opinion. And don't forget to ask white samples
Yes, that was the joke HP is ahead at least with one thing.I believe there is no white option with Epson
Once you buy that 97th 3L of ink you are at your break even point for the 800.No, they are $143 for 1L and $300 for 3L
HP Latex 700 - $17,695.00How do you mean?
Yep correct, saves you on the white ink when you don't need it and it's fairly quick process. When you put them back it's only cleaning/servicing them and you are ready to go.I was watching a video on the new printers, did I see correctly - if you aren't using white you need to remove the heads, put them in some plastic box, and back into a special section of the printer that spins them? And when you want to use white, remove, readd, print, rinse and repeat?
What is the recommendation on this? If I am not printing white for 1 day, 2 days, a week, etc, I should go through this process?
