Kentucky Wraps
Kentucky Wraps
Anyone have one yet? Worth the $7K more than the L360?
That would take a TON of ink usage to make up for the $7k difference. If I remember right when I checked, the 3 liter boxes ended up like 5¢ per ml cheaper.
This isn't the 4th Gen-- it's simply the 3rd gen w/ bulk ink.
Can the 370 print a 150' or 164' roll of vinyl at once without melting the print heads?
Assuming they haven't changed anything from the 360 then yes. I print full rolls 150' long on full heat with no problems on my L360. Did the same with my L255001st gen never had an issue with melting heads. Not sure where that comes from. Sounds like you may have had a bad heater or heat sensor that wasn't heating your unit correctly.
Probably just me. We have a L26500 that has had head and temperature issues. I am currently getting 1500 - 2000ml life from the print heads. HP has advised me to not run lengths longer that 280"- 300" at one time.
I guess I'm just old school. Solvent (true solvent), Aqueous and UV. I understand the technology, the principles, but am not seeing where it is any savings or maintenance time. It is easier to print on some substrates, but harder to print on others. With every print format, you have to be well informed to pick what is right for your shop.
You do realize that the heads are not warrantied beyond 1 liter of ink. So if you're in the 1.5l to 2L--
