jasonx
To answer a few questions:
There is no flushing necessary because of the recirculating of the ink. There is still waste, 1.5ml every 12 hours due to self cleaning and 6ml when firing up the metallic. So print all your metallic at once or very close together.
As far as restitution they replaced my wasted roll with a high end cast roll and gave me a roll of photo paper. They gave me some partially filled CMYK cartridges and are sending a replacement metallic cartridge.
If its using 1.5ml every 12 hours that isn't so bad that's about 90ml a month. It's a lot less then the current XC540W where you do flushes twice a month and use a lot more ink then this.
Do you get prompted to do ink renewals before you print with the MT?
I've found you get this with the XC540W. Its only a problem when your doing an overnight print run and it comes up during your print run and the whole process pauses. Mine tends to come up at midnight for some strange reason.
