Newb Help Needed ASAP!!
SpazSigns
After i do an autotrace and send to plotter it goes over the same pattern three times, i checked to make sure that i had it set to one pass and that was correct, Is their something im not doing right after i trace?? Im a newb so any help appreciated!! Im going to put a picture of it up soon!! thanks guys n gals!!
Sign_Language
It seems as if it is cutting your actual shape plus a stroke that is present.
Delete the stroke, or if it is needed for thickness......convert strokes to outlines and weld.
Shovelhead
And....
Why Don't You Have Your Computer Firewalled?
What's With The Little Red "x" On The Bottom Right???
Hmmmmmmmmmmmmmmmm????
Techman
wait till he gits a dose of SmitFraud, the latest in maleware hijacking of a computer..
I just licked a client for $175 to remove smitfraud.. and pray I got it all.
Techman
that site has a good start on it. But some variants have more than what the original verion had.
ITs not all hiden in just the windows temp folder. It also hides in another place and makes a comeback... The newer variant also is more than just a security scan fraud. It comes with another backdoor trojan that makes for more hassles.
I got that $175.00 because my time is worth it.
thewood
Your client got a deal. I got a nasty case of the SmitFraud. I ran every virus scan/spyware/registry program I could get me hands on--even an app designed exclusively to remove SmitFraud. I got nowhere. So I took it to my tech guy. After almost 2 weeks of tinkering (one of which we were closed for business) he tapped out. I saved the data on my drives, but had to reinstall xp. That SmitFraud attacks the hell outta the OS. By the way, I was running a firewall and AVG. Somehow the antivirus got turned off. I suspect the SmitFraud disable the antivirus app.
