Next Question- VP vs SP....Battle royal!
signpro
Manager
our SP is just fine. unless you are running it constantly everyday, the SP should be just fine speedwise for you.
aren't the print heads IDENTICAL on the SP & VP, just that the VP has twice as many? quality should be nearly identical then
The print heads are the same; The VP has 4 heads; The quality is NOT the same as the VP has Intelligent Pass Control that provides better prints at higher speeds (with the latest firmware upgrade).
