Next Question- VP vs SP....Battle royal!
Discussion in 'Roland' started by vectorterrorist, Mar 17, 2009.
  1. vectorterrorist
    vectorterrorist Member
    152
    First off many thank yous to everyone who shared thier insight on the sp 540 thread- I toast my :bushmill:to ya'
    I have a new question- so turns out the SP I was going to look at last night was a craigslist scam. when I called the guy to come see the pritner he gave every excuse for not allowing me to come over after we had a set appointment we made from the previous day.
    I know the VP is the more modern printer but I guess my question is about the quality of a SP vs the quality of a VP. I woul dlike to do mx graphics and I am pretty picky about about quality. Some of you mentioned a quality factor with the 2 printers...is the quality really noticable or would the SP be fine for this type of application...reason is I can find all kinds of SP540's for sale but cant find a VP540 for sale..and I'm kinda set on a 54 vs a 30" so I can do more stuff down the road-
    Thanks and happy st. paddies!
  2. threeputt
    threeputt Very Active Member
    3,389
    1
    38
    Mar 10, 2006
    washington state
    Does the VP have additional print heads? (more than the two in the SP)
  3. zmatalucci
    zmatalucci Very Active Member
    quality wise, I know the Sp more than holds its own. I have done some extremely detailed prints that are displayed in a museum, and I have never heard anything negative about them.
  4. synergy_jim
    synergy_jim Very Active Member
    for the money.... if you don't need the extra speed, buy the sp. We loved ours, but we needed way more throughput and a robust take up system.
    Thats the only reason we sold it.
  5. synergy_jim
    and by the way.....
    we had our sp300 for 3 years and printed the balls of that thing. The guy I sold it too has had it for 2 years and still has not replaced a single part on the thing...
  6. vectorterrorist
    152
    customer
    Through a customers eyes...would they be able to tell a quality difference between the 2 printers if I had something done on each machine? I've seen the quality of a vp so I just want to make sure a sp would not be considerably different in this area-
  7. Bigdawg
    Bigdawg Just Me
    7,459
    133
    63
    Jun 8, 2005
    Sunny Florida
    I have some decals that were done on both... they are very fine reversed out type. I see a difference... I think the customer - IF THEY LOOKED HARD ENOUGH - would see a difference.
    Most of 'em (customers) don't pay any attention as long as it's legible... but then there's the ones that demand perfection.
  8. Doyle
    Doyle Very Active Member
    2,533
    4
    38
    Dec 4, 2006
    Michigan
    I have owned a SP for about 4 years and can tell you that no customer of mine has ever complained about quality, prints very nice.... though I have not compared it to a VP, I think that for MX graphics a SP would more than suffice. Print speed is a little slow, especially if you are printing on high quality (which I hardly ever use).
  9. petepaz
    petepaz Major Contributor
    4,340
    82
    48
    Feb 14, 2007
    NJ/NY/PA
    both machines are the same dpi we have both and so far they are both work horses
    the vp does have an addition print head that's why it print faster and the only quality difference we noticed was we get alittle better color out of the vp
    your customer will not know the difference
    next question do you have a laminator because which ever machine you get you are going to have to laminate the decals
  10. design unfolds
    design unfolds Member
    50
    Just wonder why laminate the print if Eco solvent ink are water proof already? What is the different?
  11. B Snyder
    B Snyder Very Active Member
    1,433
    Laminate for protection from chemicals and abrasion.
  12. petepaz
    4,340
    82
    48
    Feb 14, 2007
    NJ/NY/PA
    yeah what B said also helps with uv /sun light protection
  13. GSSA-Russ
    GSSA-Russ New Member
    16
    I agree with everyone above, but definitely get the 540 if you are thinking about getting into more stuff down the road, you will quickly outgrow the 300.
    Speed is the main factor other than the two additional print heads in the VP model. Most upgrade to the VP because of the speed issue that's why you see more SP's available than VP's. Pick up the SP save yourself some coin, and grow your business until your abundance of customers force you into a faster machine.
  14. petepaz
    4,340
    82
    48
    Feb 14, 2007
    NJ/NY/PA
    we had the sp300 for 6 months and then bought the vp540
    we out grew the sp300 that fast and now we run both machines like crazy
  15. Mike_Koval
    Mike_Koval Active Member
    629
    2
    18
    Mar 20, 2008
    Uniontown, PA
    biggest complaint of a 30" machine..."I wish I had went with the 54"!" that is me quoting most customers that have a 30.
  16. synergy_jim
    I agree.... if you can swing it, get the 54" for sure...
    and buy a laminator....
  17. Pacific Coast Sign
    Pacific Coast Sign Active Member
    548
    1
    18
    Jun 19, 2008
    Portland, OR
    The VP models now have the intelligent pass control (like the XJ and XC models), this new firmware upgrade GREATLY improves print quality and especially at higher speeds (no banding!).
    The VP has a cog belt (like a timing belt) that runs the carriage very smoothly, the SP has a cable that stretches over time and needs many adjustments to keep the contour cut on line.
    The VP is a much more reliable printer overall...all though I still like the old SP's too.
    The VP comes with a 2 year warranty if you register the printer with Roland - only a one year if you don't....so PLEASE be SURE to register your printers!
  18. lfalsetto
    lfalsetto New Member
    13
    subscribe
  19. biggieg
    biggieg Member
    238
    May 20, 2008
    Texas
    The only down side I see to my Sp540 is it is SLOW... But no complaints on print quality and 75% of our business is MX Graphics.
  20. Riskok
    Riskok Member
    191
    Mar 7, 2009
    Sweden
    Same thing for me whit my Sp-540 and we also do 60-70% MX Graphic.
    But I think it works fine. The printing takes some time but I haven’t got a hang of the laminating yet so it takes more time ;)
    BR Patrik
