Signsforwhile
Have our first Nissan NV van.....what are u guys lining up on?
depends where you're putting stuff. tape it up and stand back like everything else. if it aint right then adjust and look again.
Also, not sure if your customers are "picky" (crazy would be ab better word), but we have a couple that like things to be aligned just the reverse, or exact measurements off of odd things. But you should already know which customers to watch out for...
Just me but I've always found the "Stand back and eye it out" technique to be risky because like I said in my last post...if the ground you are standing on or the vehicle is parked on isn't level you're screwed.... If you use vehicle lines to line up then you can always argue that point. If you use the ground, your argument then becomes.. "well it was straight in our shop..."
On a side note....always assume the customer is crazy. They usually don't show it until it's too late.
Measure it to be parallel with the lines on the vehicle, or eyeball it somewhere in between the lines if the vehicle has too many angles. That's the best you can do I think - maybe tape it up on the vehicle and confirm with the customer before they leave you to it.
I don't see how the ground being level has anything to do with vehicle graphics - you would never use a level on vehicle installs.
