Roland SP 300v
listed are the following steps ive taken so far:
replaced the heads
replaced the captops
replaced the fuses on the main board (this was the issue last time this happened and replaced with sockets to avoid this issue in the future)
swapped the head wires on the carriage (magenta and yellow print on either set of ports)
replaced only the black and cyan print head to verify (unless i have two bad print heads that cant be the issue)
im about to say screw it and retire this machine which i really cant afford as it would mean the end to my small business. are there any other things i should check or try?
replaced the heads
