Question Not quite sure what it's called.........................
Had a customer request some small signs to be printed both sides. However the specs are 11" x 13" with a bleed on 100lb gloss paper.
Years ago, I hand painted on plenty of 110lb offset paper, but it was far from glossy. What would this equate to for eco-solvent printers ??
:thankyou: Gino
unclebun
I've never seen a double sided photo paper for large format. Is it made? Seems like that spec is intending something run on a color printer or copier with sheet stock.
That's what I was thinking. I can't find double-sided stuff........ 100lb, yet.
Dan360
You'll have to look at the GSM, the poster paper we use is 8mil and 231 GSM. 100lb cover is about 270 GSM. So maybe around 10mil?
Not sure what the equivalent is for large format, we throw this kind of stuff on the copier.
Well, I got around it by offering a piece twice as high and folding it over as one side is different from the other side. It slides into a plexi holder, so I don't really know why it hasta be glossy paper, either.
Thanks for the help and input. :toasting:
Grizzly
It’s all about your print!
100lb Gloss Text/Book and 100lb Gloss book are both common products printed two sides. Mostly used in commercial printing world.
