Really?
In order to hypothesize the existence of a something its mechanism must be demonstrated. Otherwise all you have is mindless belief.
Do not confuse confirming**  that something does not exist with dis-proving an hypothesis that it does exist. Two very different propositions.
**Hypotheses are incapable of proof. They may only be confirmed or dis-proven. Never proven.
Your daily lesson on scientific method and confirmation theory.
This is fun. Engaging in something other than politics anyway. Regardless of who I believe is right or wrong, this type of discourse applies to many arenas in life and unfortunately
most people don't know why or how they came to their beliefs. As long as it doesn't become a personal attack and we stick to dismantling or addressing the argument and not the
arguer, it can be a productive process.
•Boiled down version...
We observe the problem & attribute it to  lack of "out gassing" because that is the consistent factor among the  variables when we experience it. (demonstrated on the video)
You  discredit such a conclusion because you "believe" out gassing to be  myth. You base this belief on an apparent false understanding of how  solvents, laminates, vinyl, & adhesives "should" behave under such  circumstances.
•Long version
What accepted scientific principles are being violated by our "hypothesis"? Have you stated any, other than how you personally "believe" the solvent "should" affect the adhesive.
Since ALL scientific principles lie on the presumption that the future will be like the observable past using the high level of predictability based on observations of past and current events. I'm well versed in scientific method.
•You've hypothesized that the solvent does not affect the adhesive. Your support for that idea is that you don't observe anomalies between the lamination and the ink.
•You reason that such anomalies should manifest if there are any reactions significant enough to compromise the adhesive which is on the back side of the vinyl.
Not to mention you've not accounted for how the adhesive is more aggressive when not "out gassed". You've speculated it may be due to high temperatures, but we've already stated that is not the case.
Our conclusions are based on observation.  I don't think that is considered "mindless belief". Our reasons don't have to satisfy your understanding in order to be correct or plausible.
The fact is that our (active wrappers, video, vinyl manufacturers) conclusions don't agree with your understanding of how it "should" behave.
You've only listed notions that you feel the material reactions should follow if out gassing were real.
Those "straw man" premises are what you are using to support your conclusion. Those aren't scientific principles.
