one shot on latex
wes70
How good does one shot adhere and cover over latex? I am applying a mask (text cut-out) over mdo that has a latex finish. I was going to use latex paint, but I was thinking one shot would cover with one coat. Should I stick with latex on latex?
G-Artist
I have used it on top of lots of other type of paints and surfaces with no adhesion problems.
As to one coat coverage - that depends. Lettering enamel, probably. Bulletin colors, maybe not.
I'd be a bit concerned with the mask on latex if the latex is fresh paint. Removing the mask could cause paint removal as well. Test in a non-conspicuous area. We squeege the heck out of mask to insure crisp lines. Doing it on fresh paint can cause problems.
Jillbeans
When doing handlettering, 1S is fine over latex, I have been doing it since 1985.
BUT when using a mask, latex peels right off the substrate when you pull up the mask.
I mean down to the primer and sometimes even bare wood.
I wouldn't advise doing this.
Pounce patterns would work fine though.
Love....Jill
wes70
I have always used latex when using a mask, but depending if the latex is clear base or not, it takes 2-3 coats to cover properly. I want a paint that is more opaque, that is why I am considering one shot lettering enamel.
wes70
Thanks G and Jill,
I've had great results using calendered vinyl as a mask. Nice crisp edges, with latex and oil, with no paint lift when removing.
Forum Studio
MACTAC - MACmark-grey transparent paint mask.The adhesive is ultra removable
and design for plotter cutting.Removes very clean with no glue residue.As decorative painter I use this mask for few years. Always with excellent results.
I use TrnsferRite Ultra-transparent as premask.I hope this will help. Cheers.
Craig Sjoquist
Latex seems to allow many a paints to adhere with no problems ...proper prep /color painted / drying.. removable vinyl should not be a problem either
