altereddezignz
I am loosing my mind i think but can someone please tell me how to cut a simple cut path file. No print no contour cut. Like i want to cut my name out of white vinyl saved as an illustrator file?
There are tons of ONYX videos on youtube, I've learned a lot from them in the last while.
I haven't used CutServer yet but hopefully this helps (just ignore the print part if you're doing cut only) Contour Cutting Workflow for X10 - YouTube
In the svg you need to save each color as an individual layer. Hover over one in cut server, right click and choose new cut path, it will separate it out to a new layer. Then you can cut them individually.
Use Cutting Master plugin for Illustrator. It may be a Graphtec only plugin though. What type of cutter do you have?Just cut right out of Illustrator
I use Illustrator cc 2015.3 (Latest Release before CC 2017).Will not work with Illustrator cc
I actually use Cutting Master 2 (Which shouldn't technically work but i just moved some files around and made it work) because I don't really like Cutting Master 3.
Graphtec America: Supports/Downloads - Cutting Plotters - Discontinued/Legacy Cutting Plotters - CE5000 Series
