niwbie-colorado
Hi all;
I'm having an overlap issue on my Canon Colorado M5W machine at the office.
Example, today I do a test print of 3 tiles for my 110cm wide media. My order is w 315 h 260 cm and I divided each panel into 104cm under the onyx Tile tab. My overlap margin is 10mm. I used a 2px cutting marker under the Marks tab. When sending the media to the printer, I selected the "110cm Enhanced" option and ROBUST was selected as the AAC option. I calibrated the media before printing. I also performed Carrige Calibration on the printer and then printed my order.
Now, when I cut the panels at the Tile Marks and placed them side by side, they still did not weld. I have an overlap problem.
Here I add some pictures about the pipeline.
Our media: m1jpg
onyx ver: 22.00.2449
placement set + selected media: m2jpg
tile overlap nd marks set : m3jpg
overlap problem: m4jpg ( you can see the overlap problem)
cutting marks: m5jpg (When I cut from the cutting marks, there is no weld two panels.)
Order Height measurement is 260 cm. but when I measure the panels, the first panel is 206.03cm, the second panel is 206.2cm and the last panel is 260cm. In other words, the lengths of the panels are not equal to each other and are getting shorter.
I guess that's why the panels don't weld together.
Do you think this is the problem, how can I solve it?
Thank you everyone in advance.
Our media: m1jpg
