Onyx SignEZ...can it be installed into windows 7?
tbullo
Superunknown
My windows XP motherboard just went out. I use the Onyx signez program that came with my HP8000. I was wondering if anyone has had any luck installing this into windows 7. When I try to install I get a message ''You have to run the 64 bit version of DPInst.exe on this machine". Help...:banghead:
eahicks
Sounds like you are installing on a 64bit version of 7....you have to install/run it in Compatibility Mode (for backwards compatibility). Pretty sure EZ is ONLY for 32bit Windows.
