Outline problem
Discussion in 'Corel' started by Erin, Dec 6, 2006.
  1. Erin
    Erin Active Member
    504
    First of all before I forget to mention it...I am using corel draw 11.
    I hope I can explain this properly...
    I have some text with an out line and I want to convert the outline to an object. The problem is whenever I do this the lines all break up completely. What I mean is the outline isn't solid and I have to select all the pieces and weld them together. Then there are anywhere from 2 to 8 nodes I have to reconnect for it to be a solid image again. It seems to happen no matter what text I am using. Is there something I'm doing wrong or is there something I can do differently so this doesn't keep happening? It is very annoying and becoming quite time consuming on little jobs that shouldn't be very time consuming.
  2. bob
    bob Major Contributor
    5,273
    306
    83
    Nov 4, 2005
    earth
    What font?
    If you have some low rent font file with knots in the the various characters you'll see this phenomenon. Try switching to wire frame mode and zoom in as close as you can on the area of the malfeasant outlines. See if there isn't a knot or some other perturbation in the character outline at that point. If you don't see anything, try converting the text to curves and look again. Look carefully, the anomalies can be rather subtle.
  3. ChiknNutz
    ChiknNutz Major Contributor
    4,789
    2
    Although not really the answer, x3 seems to do a lot better job in the way it handles contours and outlines. Depending on the design intent, you may yield better results using the Interactive Contour tool.
  4. Checkers
    Checkers Very Active Member
    2,698
    3
    Chris is right.
    A well known font manufacturer actually suggests that you should use the contour tool to put an outline on their fonts.
    In 12 and older versions of Corel, you will get a lot of nodes. However, I was told that the node problem is fixed in Corel X3.
    Checkers
