First of all before I forget to mention it...I am using corel draw 11.
I hope I can explain this properly...
I have some text with an out line and I want to convert the outline to an object. The problem is whenever I do this the lines all break up completely. What I mean is the outline isn't solid and I have to select all the pieces and weld them together. Then there are anywhere from 2 to 8 nodes I have to reconnect for it to be a solid image again. It seems to happen no matter what text I am using. Is there something I'm doing wrong or is there something I can do differently so this doesn't keep happening? It is very annoying and becoming quite time consuming on little jobs that shouldn't be very time consuming.
