outline procedure
Justin
You'll be much better off using offset path if your cutting vinyl vs printing it.. Why you ask? When you do offset path, and ungroup the outline you have a full backing.. When you do outline stroke it only gives you the stroke of the outline where the "inside" is hollow basically.
Basically,
Offset - you lay whatever you offset ontop your offset.
Outline stroke - you lay whatever you outlined inside.
