signbrad
The job looks fine, nolanola.
I am curious which of the Graco True Coat model guns you used.
Has anyone used the cordless?
If anyone is curious, I worked at a shop for about a year back in the 80s that regularly installed large Gatorfoam letters outside, simply gluing them to walls. They generally looked good about two years, though some lasted far longer. They were not intended to be long-term signs. I painted hundreds of them personally, using acrylic enamel automotive paint (catalyzed). I primed edges with latex, usually a triple coat, keeping the faces wiped clean. Painting the backs not only kept them from curling, but permitted a better bond for the silicone used for installing.
I don't have experience using Ultraboard, but I understand that the overlay is a plastic rather than a wood product, so I would expect a binding primer to be necessary for topcoat adhesion.
Brad in Kansas City
Brad in Kansas City
